Header Size? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-25-2013, 04:04 PM   #1
n2omichael's Avatar
Rewards Points: 115
Header size?
Hi guys
I have decided to put a man door in my basement which is. 42" of concrete and 48" of wood knee wall.
Can someone tell me how big (wide) the header needs to be for a 30-32" man door? I was told 1" for every foot of span, so 2x4's would do, I have had others insist I need to use 2x8's or larger, so I would like an answer from someone on here, since guys here seem to REALLY know their stuff (-:
The building above is a single storey wood framed cottage about 800 sq ft. I had planned on using triple 2x8 posts to support the header
ALL input is welcome, Thanks!
Michael
n2omichael is offline   Reply With Quote
Old 09-25-2013, 05:42 PM   #2
Rewards Points: 3,130
So what is a "man door?" Are you talking about adding an exterior door in the basement? If so, how do you intend to use 2x8 studs? I can't imagine the framed part of your wall is that thick. Also, if this is indeed to be an exterior door, I believe code requires it to be at least 36" wide. I've also never seen an exterior door header that was less than 2x6.
Forgive the inference, but your questions lead me to suspect you don't know what you're doing.
The Following User Says Thank You to md2lgyk For This Useful Post:
woodworkbykirk (09-25-2013)
Old 09-25-2013, 05:45 PM   #3
cortell's Avatar
Rewards Points: 504
The simple answer is that 2x8 should be fine except if you have high snow loads, in which case go with 2x10. This is assuming you're using #2 or better Southern Yellow Pine. But don't trust me (or anyone else who gives you simple answers on the internet) :-). http://www.southernpine.com/pdf/ref207.pdf
cortell is offline   Reply With Quote
Old 09-25-2013, 05:46 PM   #4
n2omichael's Avatar
Rewards Points: 115
Yes, exterior door, doesn't have to be 36" (at least where I am) concrete foundation is 8" thick and knee wall is framed with 2x8's. The door I looked at has a frame and door all together, installed as a unit. Door frame is just over 7" wide .
Old 09-25-2013, 05:51 PM   #5
n2omichael's Avatar
Rewards Points: 115
Thank you Cortell
That's the answer I was looking for, I had planned on buying the lumber from a big box store. Not sure how good the quality of their wood is? There isn't much in the way of snow loads, it's a peaked steel roof with a significant pitch, should be good with 2x8's
Thanks!
Michael
Old 09-25-2013, 06:36 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,116
you never stated what direction the joists are running. if there are joists bearing on the wall that the door will be in i would be using 2x10 or atleast a triple 2x8.
as for entry door size 32" is the minimum in most areas
woodworkbykirk is offline   Reply With Quote
Old 09-25-2013, 06:41 PM   #7
n2omichael's Avatar
Rewards Points: 115
The floor joists ARE load bearing on the wall I had planned on using triple 2x?'s with a piece of plywood sandwiched between to make up the difference in width. The door I looked at was 30" but I could have misread the label, will call tommorow and ask, the cottage is on an Island and building regs are pretty lax to say the least.
Old 09-25-2013, 08:56 PM   #8
cortell's Avatar
Rewards Points: 504
I just checked the 2006 IRC. For an opening in an exterior wall that's holding up a roof, ceiling and one clear span floor, a header composed of two 2x8s would safely span 3'6", and that's in the worst case. Worst case means very heavy (70 psf) ground snow load, and a building that's 36' wide. Note that these calculations (and the document I linked) assume the floor joists are bearing on the wall.
Also, you'll need two jack posts under each end of the header.
Old 09-25-2013, 10:50 PM   #9
Registered User
Rewards Points: 5,498
IRC; http://publicecodes.cyberregs.com/ic...9_5_par024.htm figure your local snow load...
Gary
Old 09-25-2013, 10:52 PM   #10
n2omichael's Avatar
Rewards Points: 115
Thanks for the Input and links, I'm in Ontario, Canada so we get a fair amount of snow, but, not as much as some places!
Thanks Again!
Michael
What size header to attach for lattice patio cover to stucco wall? Slammed01 Building & Construction 12 05-14-2013 12:10 AM
Need to determine proper Basement Window Header size- AdamH Building & Construction 1 11-23-2011 02:59 PM
Raising header to install standard size door (photos) JustADoc Building & Construction 8 08-10-2011 04:42 PM
what size header should i use? jakejr13 Remodeling 1 07-25-2010 05:46 PM
framing and header size for garden shed jcall100 Building & Construction 1 07-11-2010 07:29 PM
