Header Size For A 18 Ft. Span - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-16-2012, 12:50 AM   #1
header size for a 18 ft. span
I am removing a partial bearimg wall and putting in a full lenght beam instead over 18 ft. This is in Hawaii so no snow.
Nytzzz is offline   Reply With Quote
Old 04-16-2012, 08:43 AM   #2
Stay-at-home GC
It should be 18' long.
Sorry, I couldn't resist. Not sure if you're going to get an answer here. The guys who know aren't telling and if they were its too dangerous to do over the Internet.
Pay a local Engineer a few hundred bucks and sleep soundly at night.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 04-16-2012, 08:43 AM   #3
Civil Engineer
Rewards Points: 4,580
I have never been to Hawaii, perhaps post some photos, I understand the scenery is great.
Old 04-16-2012, 03:25 PM   #4
Rewards Points: 660
Whatcha, bragging? We had some sloppy flakes this morning still.
Well, In Minnesota we don't have any tsunamis!
B
Beepster is offline   Reply With Quote
Old 04-16-2012, 11:29 PM   #5
Rewards Points: 940
You might want to tell what the beam will be supporting.
cleveman is offline   Reply With Quote
Old 04-17-2012, 07:33 AM   #6
Stay-at-home GC
After posting this I thought about how it sounded.
I don't want to give the wrong impression about the regular members here. They are a great bunch of people and you won't find a nicer group anywhere.
Its not that they won't answer, rather they are reluctant to answer lest something is missed in the translation and someone gets hurt.
Old 04-17-2012, 10:31 PM   #7
You can use 2 or 3 18' LVL (10"/12") whatever u like and put a good solid post on each end 3 2x6 nailed to each other should do just fine
ninjahero is offline   Reply With Quote
Old 04-17-2012, 10:34 PM   #8
two 9.5" deep lvls on an 18' span seems light but i don't really know what's above it.
itsnotrequired is offline   Reply With Quote
Old 04-17-2012, 10:51 PM   #9
They will still work and thats a good question
Old 04-17-2012, 11:21 PM   #10
there is also the question of meeting code vs getting what you want. the floors may be bouncy as hell and still meet code but i would rather exceed code and minimize bounce than live in a romper room.
Old 04-18-2012, 12:13 AM   #11
Rewards Points: 214
NYTZZZ,
It's like others have pointed out. You really should consult an engineer for a definitive answer.
There are still snow load consideration from what I came across with Hawaii.
*You can visit THIS site for some snow load considerations and some other good details.
*You can visit THIS IBC tables, as the above references, in getting an idea of what might be required for a header. That page is possibly dated though, so you would need to verify whether it is still applicable for you.
*THIS is an alternative to the IRC table and again just in giving an idea of what is considered. An engineer can give proper requirements and/or alternatives.
This is just FYI in possibly getting you in the right direction....
Good luck
Ralph III is offline   Reply With Quote
Old 04-18-2012, 11:12 AM   #12
Rewards Points: 2,210
MY local Lumber yard will size the necessary LVL or GlueLam for me. They get the truss manufacturer to do it. I just tell them what it is for and what it supports.
mae-ling is offline   Reply With Quote
Old 04-18-2012, 11:15 AM   #13
Civil Engineer
Maeling, how do you get a truss manufacturer to size a Glulam or LVL? Neither of these are trusses, and it would be a coincidence if a truss manufacturer also happened to manufacture Glulams or LVLs.
Old 04-18-2012, 07:20 PM   #14
The lumber yard gets these and I joists through the Truss manufacturer and as such their engineers do the calculations.
Old 04-18-2012, 08:56 PM   #15
Totally agree with u me personally I always try to exceed code in watever I do
header size billbagwell Remodeling 1 11-10-2010 09:12 PM
Header size warnerww Building & Construction 3 01-27-2010 11:48 AM
Header span question dfwskymaster Building & Construction 3 06-24-2009 11:06 PM
Header size question BimmerRacer Carpentry 18 03-01-2009 08:51 PM
Header span? beaver7 General DIY Discussions 2 02-24-2009 06:50 AM
