Header Size - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 08:31 PM   #1
Rewards Points: 14
Header Size
Hello all, I have a lean to shelter built on the back of my shop measuring 14x30. The top consists of 2x6 on 24'' centers stripped with 2x4 on 24'' center. 36'' 28 ga metal roofing on top.I have post on each end and one in the middle that I would like to remove.Header size is 2x8 with 1/2'' plywood in between.Could I bolt steel plate to the existing header for support? Please advise. Glenn Middle Georgia
G Archer is offline   Reply With Quote
Old 07-11-2012, 09:12 PM   #2
Rewards Points: 2,210
Do you need permits?
mae-ling is offline   Reply With Quote
Old 07-11-2012, 09:14 PM   #3
You have the double 2x8 spanning 15'? 1/2 the 30'.
30' is a long span for a non engineered beam.
The Following User Says Thank You to mae-ling For This Useful Post:
CopperClad (07-11-2012)
Old 07-11-2012, 09:15 PM   #4
So its 30' long. You have a post in the middle that you want to remove. By the information you have provided, the double 2x8 header with ply would have to break on the center post. It would take a pretty long piece of steel say 8' front and back of the header , minimum thickness of 1/2'' steel with minimum 12- 6''x 3/4'' ASTM325 through bolts.. Gotta ask.. Why do you want to remove this post.
CopperClad is offline   Reply With Quote
Old 07-11-2012, 09:18 PM   #5
Not only is it way to long he wants to remove the only thing holding it up.. He should be asking how many more posts he should put under it .
Old 07-11-2012, 09:24 PM   #6
liscenced electrician
Rewards Points: 538
There is more to the size of a header than just how long of a span. Weight of the roof and how much weight is being put on it as well as unsupported length.
To answer your question. I don't think bolting on some steel would be sufficient. How about some pics?
jimmy21 is offline   Reply With Quote
The Following User Says Thank You to jimmy21 For This Useful Post:
mae-ling (07-11-2012)
Need to determine proper Basement Window Header size- AdamH Building & Construction 1 11-23-2011 03:59 PM
Raising header to install standard size door (photos) JustADoc Building & Construction 8 08-10-2011 05:42 PM
what size header should i use? jakejr13 Remodeling 1 07-25-2010 06:46 PM
framing and header size for garden shed jcall100 Building & Construction 1 07-11-2010 08:29 PM
Framing for Header in Basement Red Truck Remodeling 7 03-18-2010 09:11 PM
