Header Size - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 07:36 AM   #1
header size
I have an old 2 story home. Studs are 24 OC. A single story bedroom was attached to it and has a shed roof. I want to make a 48 inch wide opening I the wall to get access from the second floor. What size header do I need
jmr5128 is offline   Reply With Quote
Old 01-17-2012, 07:53 AM   #2
Retired carpenter
You want to cut an opening in a second-floor wall to access what? The bedroom's shed roof?
abracaboom is offline   Reply With Quote
Old 01-17-2012, 09:18 AM   #3
Gymschu's Avatar
Rewards Points: 846
Pics would help.
Gymschu is online now   Reply With Quote
Old 01-17-2012, 09:56 AM   #4
Yep.My furnace is in there.
Old 01-17-2012, 10:32 AM   #5
Retired carpenter
If your house is old, studs are probably 2x4s. That wall is probably holding only the weight of the roof. Do you get much snow?
Old 01-17-2012, 12:30 PM   #6
I live in southern michigan so some winters we do
Old 01-17-2012, 09:24 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
2 ply 2x10 54" long to allow for double jack studs on both sides of the opening.. if not that a 4x10 based on whats available from the lumberyards
woodworkbykirk is offline   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
jmr5128 (01-18-2012), mae-ling (01-18-2012)
Need to determine proper Basement Window Header size- AdamH Building & Construction 1 11-23-2011 02:59 PM
Raising header to install standard size door (photos) JustADoc Building & Construction 8 08-10-2011 04:42 PM
Any ideas how to deal with hidden header? loftezy Building & Construction 2 05-04-2011 05:19 PM
what size header should i use? jakejr13 Remodeling 1 07-25-2010 05:46 PM
framing and header size for garden shed jcall100 Building & Construction 1 07-11-2010 07:29 PM
