#1 |
Header Question - doubled LVL
Quick question... or at least it should be, right?
![]() Framing a load-bearing wall in need of a header beam that will end up being approximately 11-feet long. I'm having a hard time finding someone that will order me a 3-1/2"x14" LVL or Microllam, for some reason. But no problem getting a 1-3/4"x14" and the price is very reasonable. The 3-1/2"x14" was overkill anyway. I'm being told it is okay to double up two 1-3/4"x14" to create the 3-1/2"x14" to do this as long as they are properly joined together. What is the best technique for joining them? Construction adhesive between and staggered nail pattern from both sides? Staggered carriage bolts? Input would be appreciated! Thanks! Last edited by scootermcrad; 10-31-2012 at 01:41 PM. |
#2 |
you'll appreciate using a 2 ply instead of the 3-1/2 width. less weight to lift into place, and will have the same load bearing capacity.
each manufacturer of structural composite lumber such as laminated veneer lumber have their own attachment schedule for their products. find out from the lumber yard if it is a microlam (manufactured by ILevel) or another brand, such as Boise, LP, Rosenburg, or GP. once you know the manufacturer you can google their website and it will have that information. if you cannot find it once you know the manufacturer post back and I'll go through my product information. hope this helps
Gary "You get what you pay for, and sometimes free costs more!" |
| The Following User Says Thank You to GBrackins For This Useful Post: | mae-ling (11-05-2012) |
#3 | |
Header Question - doubled LVLQuote:
THANKS! And yes, I agree. Half the weight is GOOD! |
#4 |
Using 1-3/4" x14" LVL beams is the way to go, being LVL they are already heavier then dimensional lumber so using 2 ply LVL beams will be a lot easier to install. I just installed 4- 40'x14" LVL beams which weigh 400 lbs each which was a big job. The nailing schedules for a 14” LVL beam is nail 3- 31/4” commons in every 12” and try to stager the nails to get maximum strength.
#5 |
journeyman carpenter
2 ply lvls are all thats needed as long as you glue it and spike the snot out of it to laminate your fine.. a lvl that long is heavy enough for two people to try and place let lone a single..
if you did want single ply you would probably be looking at a glulam instead of lvl anyway |
#6 | |
AHH, SPANS!!!
#7 |
Thanks guys!
I actually pulled up the info on LVL's from the manufacturer and they did indeed have a nailing schedule for 2-ply construction headers. Thanks for the tip! Got all the info I need from that! Looking forward to working with the LVL's, actually. They are making some things possible in our house that we otherwise wouldn't have considered! Cheers! |
| The Following User Says Thank You to scootermcrad For This Useful Post: | mae-ling (11-05-2012) |
| Display Modes | |
| 2 2x12" Header - Want to remove post | edro | Carpentry | 29 | 08-19-2011 01:46 PM |
| Raising Doorway Header | edro | Building & Construction | 1 | 08-12-2011 04:57 PM |
| Any ideas how to deal with hidden header? | loftezy | Building & Construction | 2 | 05-04-2011 06:19 PM |
| Another Header Question... | Queso Bandit | Remodeling | 3 | 08-20-2010 10:52 PM |
| Header question | dc4nomore | Building & Construction | 35 | 10-12-2008 06:32 PM |
