Header Question - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-02-2012, 06:38 PM   #16
I think the OP is figuring on a 8' ceiling. Obviously there'd be a need for cripples if there was a space above the header. What I'm wondering is if he's building a 2x4 exterior wall or a 2x6
mrgins is offline   Reply With Quote
Old 02-02-2012, 07:10 PM   #17
Rewards Points: 506
OP is not building anything. OP said "I was just thinking..."
Then, OP mentioned 2x12s with 1/2" spacer. That says to me OP was thinking of a 2x4 wall. Could be interior...could be exterior.
jlmran is offline   Reply With Quote
Old 02-02-2012, 07:10 PM   #18
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,348
how low is the rough opening going to be, using a 2x10 header will put the top of the rough opening at 81 -1/8 " roughly. it must be a low window.
standard practice is to set the tops of windows at the same height of exterior doors
woodworkbykirk is offline   Reply With Quote
Old 02-02-2012, 07:12 PM   #19
Rewards Points: 506
OP is curious about insulation...not framing. THERMAL BREAKS!
Old 02-02-2012, 07:24 PM   #20
...so the thermal break in an interior header would be for...?
Old 02-02-2012, 07:28 PM   #21
Rewards Points: 506
Hot air (or cold shoulder) coming from his wife in the next room.
Good catch.
Old 02-04-2012, 08:02 PM   #22
In a little over my head
Rewards Points: 706
Like I said, I was just thinking. I've used 2x12s for headers for exterior wall openings for double doors and 5' and 6' windows. On my last (current) project, I thought about the thermal break, as I was installing batts between the studs. That chunk of wood over the doors didn't look like much insulation. Made me think about substituting 1/2" foam for the plywood.
ratherbefishing is offline   Reply With Quote
Old 02-05-2012, 10:35 PM   #23
Registered User
Rewards Points: 526
Solid wood has R-1.25 per inch, any foamboard would be an improvement. Of course, without the plywood you may need a larger header, it does add strength: http://www.finehomebuilding.com/how-...-up-beams.aspx
Gary
ceiling header harsuwind Building & Construction 1 08-29-2010 11:52 PM
Deck - Header Joist Repair w/ pics DawnMarie Building & Construction 3 06-14-2010 08:25 PM
Header in a "modern brace" framed house jtpwils Carpentry 14 11-18-2008 08:24 AM
Header question dc4nomore Building & Construction 35 10-12-2008 05:32 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
