Old 11-24-2012, 12:56 PM   #1
header framing
Have an exterior wall 8' high 2" x 4" 16" on center with a 3' wide x 5 1/2" high header opening. It is a recess in the wall and does not go through to the outside. Cant fasten the header to the supporting studs from the sides. Face nail or screws. Thanks.
gt1935 is offline   Reply With Quote
Old 11-24-2012, 05:10 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
header framing
toe nail on the edge of hte header into the king studs
woodworkbykirk is offline   Reply With Quote
Old 11-25-2012, 10:11 AM   #3
AHH, SPANS!!!
header framing
as woodworkbykirk mentioned, nail the header with angled toe nails on the edges and from underneath the jack into the header. Usually the opposite side of the king stud is accessible to nail through into the header ...
hand drive is offline   Reply With Quote
Old 11-25-2012, 08:38 PM   #4
header framing
Can a 2 1/2" #8 screw be used instead of the nail? How many nails or screws needed for each side of the 2 x 8 header? Also, the short header studs from the header to top plate can they be screwed with 2 1/2" x #8 screws 2 each top and bottom of header stud total of 4 per header stud? Thanks.
Old 11-25-2012, 10:19 PM   #5
header framing
no you cant use 2 1/2's, they need to be 3 or 3 1/2's.. both through the end of the header into the king studs and at the top of the header up in to the top plate
The Following User Says Thank You to woodworkbykirk For This Useful Post:
mae-ling (11-26-2012)
Using a header hanger for window header balloon framing bnentrup Building & Construction 3 09-02-2012 09:33 AM
Framing question, basement/first floor remodel enoll Remodeling 0 02-22-2012 01:01 PM
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 03:20 PM
Framing for Header in Basement Red Truck Remodeling 7 03-18-2010 09:11 PM
correct window framing? incorrect header jingles63 Building & Construction 2 05-02-2009 02:49 PM
