Header Bolted To Block - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 09:27 PM   #1
gkaro's Avatar
header bolted to block
Hi all. Building an additional on posts-piers. There are two rows of three 12" sonotubes 7 and 14 feet from the house. Against the house the plans call for a 2 x 12 to be bolted to the block foundation.
Question...how far apart do I place the lags? I'm using the kind with the ring at the end that's threaded.
Thanks.
gkaro is offline   Reply With Quote
Old 12-17-2011, 10:00 PM   #2
Rewards Points: 1,092
Depends on the load. Hard to say over the Net, w/out info. How much house above? How much snow? Flat roof w/ traffic from the second floor? Etc.
Old 12-17-2011, 10:02 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I don't think I'd have pairs any closer than 2'. No farther than 3'.
I know that's kind of a lame answer.
I wonder how many an inspector would want.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-17-2011, 10:03 PM   #4
Military Mom of 4
Snav's Avatar
Technically: it's a ledger board.
2 every 16" on center - alternating top and bottom. . . like a zigzag. (aka: 1 every 8 inches - top/bottom/top/bottom)
Depending on where you live: there may or may not be any sort of code you have to follow - there's no code for me. . . but research that and go by what they say if it's different than what you find online.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 12-17-2011, 10:05 PM   #5
Disabled wood vet
titanoman's Avatar
Try not to hit the same block too many times as not to fracture it.
The Following 2 Users Say Thank You to titanoman For This Useful Post:
Snav (12-17-2011), woodworkbykirk (12-18-2011)
Old 12-17-2011, 10:05 PM   #6
gkaro's Avatar
Let's say that I would like to make it as strong as possible.
The guy that put it up today placed only one in the centre about 3 feet apart. Is this wrong?
Old 12-17-2011, 10:07 PM   #7
Disabled wood vet
titanoman's Avatar
They should be in pairs, top and bottom of the ledger.
Old 12-17-2011, 10:08 PM   #8
Military Mom of 4
Snav's Avatar
That seems too little - 3' apart.
The anchors transfer the deck load from your deck posts to the side of the house: too few and you have too much load localized in one area - which can put a lot of pressure and lead to weakening/fracture and damage of the brick and of the lags.
Too many and the same issues can result - as titanoman pointed out - if you sink them through teh same brick it'll cause problems. If you sink it through the same row of brick too close together it'll cause problems.
Old 12-18-2011, 09:06 AM   #9
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
What I want to know is, why don't the plans call this out?
Andy.
AndyGump is offline   Reply With Quote
Old 12-18-2011, 09:13 AM   #10
Experienced
Jackofall1's Avatar
Exactly, Andy has a point, the plans should call out the spacing and size of fastener. Not on the plans? Call the designer and ask would be the safest way.
Mark
Garage Header rwbil Building & Construction 11 09-16-2010 11:50 AM
header on block wall KarlJay Building & Construction 2 09-10-2010 07:55 AM
Raise header of house wall plus add more header capslock Building & Construction 22 02-01-2010 09:13 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
