Old 01-04-2013, 09:13 PM   #1
header beam where to buy
so where can one go to buy a 20'clear span header beam do they make them that long ,is lvl ?stronger than say 2x12x1/2 ply 2x12x1/2 ply 2x12, just looking an thinging of a plan
txny13 is offline   Reply With Quote
Old 01-04-2013, 10:33 PM   #2
Civil Engineer
You might start by looking at a lumber supply store.
Old 01-04-2013, 10:52 PM   #3
Framing Contractor
Any lumberyard.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-05-2013, 02:54 AM   #4
...is lvl ?stronger than say 2x12x1/2 ply 2x12x1/2 ply 2x12...
yes, if the same size. so are psl's. and, engineered beams are more structurally stable (not nearly as much shrinking, warping, twisting).
Old 01-05-2013, 08:12 AM   #5
journeyman carpenter
woodworkbykirk's Avatar
for engineered lumber you have to go to a lumberyard not a big box store. it might have to be special ordered. the size of the beam has to be spec`d by a engineer for your application too.
woodworkbykirk is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Laminate beam header for Pre hung door? spring3100 Carpentry 6 11-13-2011 07:26 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Garage Header rwbil Building & Construction 11 09-16-2010 12:50 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
