Old 05-10-2011, 01:50 PM   #1
header for air conditioner?
I want to add a wall air conditioner in one of my bedrooms. Do I need to build a header for the air conditioner or can I just frame it out with 2x4's?
thanks!
zephed666 is offline   Reply With Quote
Old 05-10-2011, 08:55 PM   #2
Household Handyman
IF you are going to be cuttin out even one 2x4 wall stud: Then a header is appropriate in this case.
Old 05-12-2011, 12:02 PM   #3
Can you put the AC under an existing window? That would make the job easier because the window's header already takes care of the structural load.
cumak is offline   Reply With Quote
Support for Header Shakemsam Building & Construction 4 12-04-2010 04:38 PM
Garage Header rwbil Building & Construction 11 09-16-2010 12:50 PM
Raise header of house wall plus add more header capslock Building & Construction 22 02-01-2010 10:13 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 04:20 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
