-   -   Having difficulty getting plumb cut for shed roof rafters (http://www.diychatroom.com/f19/having-difficulty-getting-plumb-cut-shed-roof-rafters-143384/)
humberguy 05-10-2012 09:02 PM
Im trying to make the roof for a shed im building, but can't get the plumb for the roof rafters.
Im looking on the internet to make a roof rafter, but still confused. I got the pitch level of my roof. I scaled it to 12" x 4". I made a triangle template from it and got the angle for the plumb cut, but the plumb cut not working properly.
Im really stuck. Not sure what other methods their are too find plumb cuts to are simple for me to understand.
joecaption 05-10-2012 09:06 PM
http://www.blocklayer.com/Roof/GableEng.aspx
jaydevries 05-10-2012 09:18 PM
try this link
http://www.youtube.com/watch?v=Coal9CsUHN0
Joe Carola 05-10-2012 10:17 PM
What is the span.......ridge size.....overhang and the size of the rafters?
HartKyle83 05-10-2012 10:48 PM
What do you mean you cant get the plum? Is your ridge set? Do you know what a plum cut is? Do you know what a birds mouth is. How wide is your room. If your ridge is set how high is it off of the top plate? If you answer that we can set you on you way.
humberguy 05-11-2012 01:01 PM
I got the run at 38.5 inches, the rise is 8.5 inches, I got the rafter length 39.5 inches(I'm remembering these numbers off the top of my head). I made the cut where the rafter sits on the beam. My problem is at the birdsmouth, the angle cut their isn't properly.
joed 05-11-2012 01:58 PM
those number give 12x2.6 pitch not a 12x4 pitch. That's your problem.
humberguy 05-11-2012 05:20 PM
ill try that 12x2.6 pitch and see what happens. Also my measurements were run 38.5 inches, rise 8.75 inches, and my rafter length was 39.5 inches.
kwikfishron 05-11-2012 05:31 PM
If you have the ridge set hold the rafter stock against the side of the ridge and where you want it to sit on the wall then scribe it and be done with it.
woodworkbykirk 05-11-2012 07:14 PM
i have a feeling your using the hip rafter angle on the speed square not the common rafter cut
puttster 05-11-2012 10:39 PM
Originally Posted by jaydevries (Post 919006)
Check out this guy's speed square. Looks like the 1/4" rip marks are on the wrong side!
puttster
Joe Carola 05-11-2012 11:32 PM
Where did you get your length from? If you want a 4/12 pitch....your length is 40-9/16".
