Have My Joists Shrunk ? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-15-2012, 08:02 AM   #16
Rewards Points: 240
idk when my house was built. it keeps getting older the more i live here. i just found an inspection sticker, by the phone lines. it said 2-13 on it. so i am guessing that it is at least that old.
Fix'n it is offline   Reply With Quote
Old 04-15-2012, 08:38 AM   #17
Rewards Points: 2,516
Originally Posted by Fix'n it View Post
when i was breaking out the bricks, i could hear pieces falling into the wall cavity.
i was thinking about why those bricks are there. to hold the house in place, perhaps.
I hope your conclusion(to hold the house in place) is not valid based on how you came about that conclusion (breaking out the bricks)
hammerlane is offline   Reply With Quote
Old 04-15-2012, 09:36 AM   #18
Rewards Points: 240
that wasn't a "conclusion, it was "guess". there is a lot i cannot see, because it is covered. but other than weight & friction, what is holding the framing to the foundation ? like, how a garage is bolted to the slab.
Old 04-15-2012, 11:24 PM   #19
Registered User
Rewards Points: 526
The mortar mix and brick is holding the framing in place, why are you removing it, to air seal?
You will likely need to fill some of the cells with mortar, every 6' apart and add a metal tie to the rim or joist for hold-down. Other cells can be filled with pour-in insulation to add R-value to the wall, then foamboard and canned foam. The rim MAY have some ties to mortared cells, may not......
Gary
Old 04-16-2012, 08:13 PM   #20
Rewards Points: 240
see, my "guess" may be correct
GBR. i removed 2 cells, just to see the condition of things. and to see if the house was a balloon. and it is very possible that there are some kind of anchors spaced about, i just can't see them because of the bricks.
Old 04-16-2012, 08:21 PM   #21
Rewards Points: 240
i just went down there and hammered around. i couldn't tell, by the sound, if there are any filled sections of the blocks.
Pro Advice: Repair or Replace Deck ledger board and joists? jdm001 General DIY Discussions 12 09-05-2011 09:46 PM
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 05:28 PM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 05:43 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
