Old 03-13-2008, 09:38 AM   #1
has anyone hears of a foam type log?
I have a ceiling that spans 27' 6" and i want to put a log beam along the peak insde the room for asthetics. Someone told me that I could get it made out of foam or something that doesn't weigh a thousand pounds and is easy to install. Has anyone used anything like this? Where could I find one 27" long? Any ideas?
Mike
hammer is offline   Reply With Quote
Old 03-13-2008, 05:40 PM   #2
Hammer, here is a link to FauxWoodBeams.com:
http://www.fauxwoodbeams.com/fauxbeams.php
The recording says that if you require a beam longer than 20', you can butt two beams end to end.
I hope this helps.
Handyman50 is offline   Reply With Quote
Old 03-14-2008, 01:09 AM   #3
Thank you
Reptile Cage Finished Marc10edora Project Showcase 21 11-16-2010 06:20 PM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 09:18 AM
why use paint brushes instead of foam brushes? joeyboy Painting 18 09-23-2007 06:52 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
SPF Foam Roofing on Gables? WhyMeWhyNow Roofing 3 07-25-2005 06:31 PM
