Harvey Slimline Only As Replacement Window? Totally Unclear - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-28-2010, 07:22 PM   #1
Rewards Points: 117
RESOLVED: Harvey Slimline only as Replacement Window? Totally unclear
I'm replacing about 30 windows in my house with new construction Harvey's. (Harvey Vicon Classic). There are a couple excessively narrow windows that I'd like to improve the glass size on.
They offer a SlimLine version, but as far as I can tell it is available only in Replacement windows. Is this true???
I found the Harvey rep to be unclear in this regard.
tgm1024 is offline   Reply With Quote
Old 05-28-2010, 07:34 PM   #2
kwikfishron's Avatar
Rewards Points: 376
You’ll get a better answer by beating him with a stick than you’ll get here.
kwikfishron is online now   Reply With Quote
Old 05-28-2010, 08:12 PM   #3
Rewards Points: 93
As strange as it may seem. Keep hanging up and calling back. I had the same issue with them. You get someone who is unwilling to help and then you get someone who will give you tons of info. All depends on the rep. Some are way better than others. Call unitl yyou get someoone that helps.
bfan781 is offline   Reply With Quote
Old 06-07-2010, 07:54 PM   #4
Rewards Points: 117
Ok. I finally got the answer.
"Vicon" is the new construction version of "Slimline"
"Vicon Classic" is the new construction version of "Classic"
The 2nd line was explained. The first line is attrociously bad marketing: If nearly no-one understands WTF your product is supposed to be then you better start over.
Honestly, the terms should be:
"new construction slimline"
and
"new construction classic"
I wonder if the board of directors knows how badly the names are botched?
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 11:56 AM
