Hardware For Vinyl Soffit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2012, 12:15 PM   #1
Hardware for Vinyl Soffit
I am ready to install vinyl soffit and aluminum fascia.
The vinyl soffit has slots to fasten the edges, but what is used to fasten the portion that will be under the fascia lip ? If fastened, that part will not be able to expand or contract.
Is there a tool that will cut a slot in the front part of the soffit ?
Or is it totally supported by the fascia lip ? YouTube videos show mostly screws to fasten every 2 feet or so.
Is it necessary to use rust proof hardware in this installation ?
stymie222 is offline   Reply With Quote
Old 04-18-2012, 02:35 PM   #2
MarginallyQualified
Rewards Points: 2,464
an angle or channel formed into the fascia is the simplest option...
the vinyl slips into that just as it does with the angle at the house
hth
Old 04-18-2012, 06:05 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
when i install vinyl soffit i use roofing nails through the nailing flange into the sub fascia and every 2nd peice of soffit i drive a stainless steel cladding nail in teh channel back where it will be hidden by the fascia. by doing this is helps reduce sag plus keeps the soffit running square by having more than just one fastener in it. if you dont want to use cladding nails 1/2" panhead stainless steel screws also work
woodworkbykirk is offline   Reply With Quote
Old 04-20-2012, 07:11 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
you can hard nail the soffit tight to the fascia and let it expand towards the back j channel
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
kwikfishron (04-20-2012)
Old 04-20-2012, 07:43 PM   #5
kwikfishron's Avatar
Rewards Points: 1,002
Exactly...the expansion/contraction issue with Vinyl isn't really an issue with a one or two foot piece if it's only pinned on one side.
kwikfishron is online now   Reply With Quote
Old 04-20-2012, 07:49 PM   #6
Rewards Points: 201
When I did my vinyl soffit, I didn't use use sub-soffit nor fasten the soffit panels in any way.
I just attached a row of F-channel to the wall sheathing and another row
of F-channel to the inside of the facia board at the bottom.
The interlocked soffit pieces just rest within the F-channels.
Arky
Arky217 is offline   Reply With Quote
Old 04-20-2012, 07:53 PM   #7
you can do that too,but you need to fasten the starter and the finish piece or it could unhook
Old 04-20-2012, 11:38 PM   #8
Registered User
Rewards Points: 526
Remember to vent the soffit, if required/needed.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Tom Struble (04-21-2012)
Old 04-22-2012, 10:08 AM   #9
Why are you installing vinyl soffit. The solution would be to install aluminum soffit with a pneumatic narrow crown stapler. It is a more durable product. It has a better finish so it stays clean longer and washes off better. It installs flatter and more securely. Most importantly it doesn't shatter like vinyl. I think that vinyl siding is a legitimate product but there is a reason why soffit is still made of aluminum all these years later. The only reason I can think o install vinyl is to get a bead board look. I don't think it is worth it.
HartKyle83 is offline   Reply With Quote
New siding up to existing soffit jtchavez Building & Construction 18 03-25-2012 09:48 AM
Replacing soffit tucked behind brick veneer. Queequeg152 Building & Construction 3 02-25-2012 07:10 AM
what hardware cctv to aluminum soffit D270 Building & Construction 2 04-13-2011 06:28 PM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
