Hardiplank Vs Fiberboard - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 06:26 PM   #1
NAIL BENDER's Avatar
Hardiplank vs Fiberboard
I've got a 60 year old ranch house here is Texas that has t-111 over the original 5.5 inch lap siding. The t-111 is junk and will be replaced. A prior owner drilled 1.5 inch holes in the lap siding to blow insulation in. I plan on wraping the home with a vapor barrier and wonder what are the thoughts on Hardi vs Certainteed Fiberboard...? I built a hen house with the fiberboard and a 4x8 sheet it's a lot eaiser to handle than the heavier Hardi. But, what about longevity over the lap siding. I could pull the lap and replace with OSB, but that would involve replacement of the insulation.
Give me your thoughts, I appreciate any and all input.
Thanks.
Danny
NAIL BENDER is offline   Reply With Quote
Old 02-05-2012, 11:51 PM   #2
Registered User
Rewards Points: 526
I would not attempt to install hardie panel or fiber panel over lap siding. You need a level surface or both will show imperfections, or "telegraph" the surface irregularities below. I believe you mean water resistive barrier, required by code on the exterior under the finish siding.
Gary
Old 02-06-2012, 12:08 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Gary
For what it's worth, he says he's going to replace the shadow groove over the lap siding, and then side over that?
I'm sure I'm not sure.
titanoman is offline   Reply With Quote
Old 02-06-2012, 08:29 PM   #4
Hey Guys,
You'll have to forgive me, as I do NOT know the proper terms for what I'm discussing. I do understand about fiberboard replicating any irregularities it would be placed over, but I'm thinking about replacing the t-111 panels that are currently mounted on my homes original horizontal board exterior.
This exterior is tongue & groove with approximately a 2 inch depression. My thought was if Hardi & Fiber Board can be placed on wall studs, a span of 2 inches would not be a problem. Can I be wrong...?
Here is a very poor drawing of what I want to cover with one of these new sidings...
Thanks for your insight.
Old 02-08-2012, 09:39 PM   #5
Registered User
Rewards Points: 526
Well, I'm confused- doesn't take much these days....
Pictures would help: How To Post Photos Using PhotoBucket Or Flickr
Check the manufacturers web site for the install directions, both choices may require solid studs or sheathing under them...
Gary
Old 02-10-2012, 12:50 PM   #6
Why not leave existing siding in place, then afix moisture barrier over existing siding then vertical strapping (also provides drainage channel) then new siding of choice fastened to strapping ? Strapping can be shimmed if required to deal with irregularities.
Marvel is offline   Reply With Quote
Old 02-10-2012, 02:19 PM   #7
Thanks Marvel.
That is food for thought....
Old 02-10-2012, 02:20 PM   #8
Gotta love a rainscreen wall.
Old 02-10-2012, 02:46 PM   #9
Rewards Points: 626
Gary
First off GBR is right. under the siding you should have sheathing at least 1/2 inch. Wrap that with tyvex heck even tar paper would work. Then invest in a good quality pair of siding gauges like these http://www.pactool.us/geckogauge/index.htm. I would use James Hardi hands down.
Nailbags is offline   Reply With Quote
Old 02-10-2012, 08:08 PM   #10
Those are some pretty neat little gauges.
Thanks for the link.
Old 02-10-2012, 09:21 PM   #11
Rewards Points: 626
they are worth their weight in gold I can do 3,800 SQF house in two days with just three people one to nail one to cut one pack the siding. Once the bottom course is laid it is all out done.
HardiPlank Siding - too Heavy? YukonDave Building & Construction 9 02-15-2014 01:52 PM
I guess this is a type of fiberboard? Marklar Insulation 0 09-03-2011 10:06 PM
Is there a sealant or resin for Fiberboard? ovsims HVAC 6 02-18-2011 11:33 PM
Hardiplank Siding repainting/staining cpharris Painting 1 10-21-2010 01:57 PM
Cabinet doors made of hardwood and fiberboard sil Remodeling 17 11-19-2007 10:18 AM
