Hardiplank Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 07:22 AM   #1
I am buying a house with hardiplank siding and one side of the house there are gap between the planlk which was caulked. How much space should be between the hardiplanks to avoid gaps with caulking?
Robby Brown is offline   Reply With Quote
Old 07-02-2011, 07:36 AM   #2
Rewards Points: 150
They don'r recommend at field butt joints see install instructions; http://www.jameshardie.com/pdf/insta...plank-hz10.pdf
josall is offline   Reply With Quote
The Following User Says Thank You to josall For This Useful Post:
Robby Brown (07-02-2011)
Old 07-02-2011, 07:55 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
but at one time they did and i think it was 1/8'',now they say moderate contact and use seam flashing,the ends need to be factory to factory or if cut they need to be primed
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Old 07-02-2011, 08:28 AM   #4
kwikfishron's Avatar
Rewards Points: 348
If your existing Hardi doesn’t have seam flashing then defiantly caulk the joints.
Not sure why the changed the rules on butt joints other than ascetics. They only say “not recommended” on the primed product and not “don’t do it“.
It’s tough for me to walk away from opened up butt joints flashed or not.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
Robby Brown (07-02-2011), Tom Struble (07-03-2011)
Old 07-02-2011, 10:33 AM   #5
i'd use a piece of coils stock thats color matched,i'm not a believer in surface or blind or back caulking
Old 07-02-2011, 10:50 AM   #6
Rewards Points: 348
It’s all ugly.
Old 07-02-2011, 11:26 AM   #7
that's subjective,does it do what it's intended to do?did the h.o get their money's worth? these are the questions on the merits of a siding install
Old 07-02-2011, 11:54 AM   #8
Rewards Points: 348
Not talking value, just personal taste Tom.
I just prefer the way things used to look.
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (07-02-2011)
Old 07-02-2011, 02:09 PM   #9
i understand i have my preferences too,but like you i don't let that stand in the way of a good install no matter what the material
kwikfishron (07-02-2011)
Old 07-02-2011, 11:19 PM   #10
Registered User
Rewards Points: 5,466
http://www.jameshardie.com/pdf/USTB_...utt-Joints.pdf
Gary
Gary in WA is online now   Reply With Quote
Hardiplank Installation Costs kayakmike Remodeling 6 06-27-2011 07:28 AM
hardiplank (4x8 sheet) installation costs kww Carpentry 1 08-27-2009 02:38 PM
hardiplank installation daniel martinez Building & Construction 2 08-03-2009 09:36 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Cemplank or Hardiplank installation question prstlk Building & Construction 21 08-03-2008 12:43 PM
