HardieSoffit Used As Siding With H Bar <--don't Do This - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 07:07 PM   #16
Framing Contractor
Originally Posted by slappywhite View Post
Anyway.......some of us have work to do. Point taken, please move along, nothing to see here.
Thanks to wikfishron for the good advice, and if anyone else has any constructive advice I would appreciate it. Thank you!
I guess you got what you paid for. Good luck trying to fix it.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-27-2010, 07:29 PM   #17
Registered User
Rewards Points: 526
Other than starting over, I would get some white painted metal "Z" flashing, with the 1-1/2"-2" lip. Cut the old plastic parting bead out 1" above the siding piece bottom. Tip the new flash in and under the top siding piece so siding is still 1" over the flashing top. Be sure to bend the 90* flatter (95*) for water spill. Overlap ends 12" with caulk between. Leave 1/4"gap from flash inside bend to upper siding board. Grind the nail heads off if needed on the lower edge of siding board, new nail after flash install.
Be safe, Gary
Old 07-27-2010, 10:24 PM   #18
Originally Posted by Joe Carola View Post
Hardie soffit is installed properly when.............it is installed properly...........for where it's supposed to go..... for soffit like it's supposed to be used for. What makes you think you can install soffit on the walls when it was never designed for the walls?
This is what happens when you totally disregard using a product the right way. Soffits are meant to be used a soffits, not siding.
A contractor built your house?
And you trusted him learning on your house? Was he the cheapest contractor at the time? We all have to learn somewhere, but this guy sounds like his very first project was your house. Anyone starting out with a slight bit of common sense does not use soffit for siding. Who would even be so stupid not including you comedian.
Wow, are you for real? I think in the first post of this topic, the guy admitted to knowing he screwed up. Why do you think you need to put him down even further, numerous times? Are you serious dude?
Tonglebeak is offline   Reply With Quote
Old 07-28-2010, 02:41 PM   #19
Some guys you invite over for a beer, some guys ya don't.
I'm looking forward to trying some of the constructive suggestions I've received here. Thanks again everybody.
slappywhite is offline   Reply With Quote
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Vinyl Siding Not Locking In Place Konfrst Building & Construction 13 11-17-2009 09:40 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
