HardiePanel Over Concrete Block - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 07:46 AM   #1
workshopaholic's Avatar
HardiePanel over concrete block
I want to update the exterior of a 1950s concrete block home. I was thinking of using HardiPanel as a new exterior finish. It would also allow me to re-frame the window openings and install modern windows, currently it has a mixture of single-glazed jalousie and huge single-pane windows.
However, I can find absolutely no info on installing over concrete block, just wood and steel framing. If it's on the Hardie site, it's well-hidden.
It seems that you could simply attach the panels directly to the blocks, using powder-actuated fasteners.
Any ideas?
workshopaholic is offline   Reply With Quote
Old 02-14-2012, 08:52 AM   #2
Well, after some experimentation, the PA fasteners won't work. The plastic guide fins stay around the nail and you'd have to individually remove them. Back to square one.
Old 02-14-2012, 09:32 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
look at hardies rain screen detail,your going to need to fur it
Tom Struble is offline   Reply With Quote
Old 02-14-2012, 09:46 AM   #4
Rewards Points: 14,026
Why not add foam insulation, fur it out and use vinyl siding instead?
That would be killing two birds with one stone.
I'll try and remember to post a picture later today of one I'm working one.
Those Hardi Panels love to shatter when applying, should not be installed close to the ground, brittle on the edges. Just go through a pile of them at the lumber yard and see how many are broken even before there installed.
Old 02-14-2012, 09:46 AM   #5
Yeah, that's pretty much the same conclusion I've come to. I'm concerned that the HardiPanel will have that airspace behind it, seems like it wouldn't be hard to crack/break it. I suppose I could put rigid insulation in there, but that's a lot of expense for very little gain (in Florida).
Old 02-14-2012, 09:50 AM   #6
I really dislike working with vinyl.
The Following User Says Thank You to workshopaholic For This Useful Post:
Nailbags (02-14-2012)
Old 02-14-2012, 09:55 AM   #7
What is it about it you do not like?
Old 02-14-2012, 11:13 AM   #8
it's best to have an airspace with fc,
hardie is actually pretty tuff impact wise
concrete block house shower medalta Building & Construction 3 11-02-2011 05:16 AM
Cold air coming through joist holes in concrete block foundation. Ptron Building & Construction 2 01-30-2011 04:29 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 03:55 PM
Basement Concrete Block Mortar Seepage Advice Nightcrawler Building & Construction 6 09-22-2009 08:57 PM
Can foam sealer be used to seal the spaces in concrete block? marksto Building & Construction 6 04-21-2008 07:48 AM
