Hardie Board Textured Siding Instead Of Stucco - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-21-2008, 10:00 PM   #1
Hardie Board Textured siding instead of Stucco
Has anyone ever seen/done this? I was thinking of using the hardie-board textured siding, 4x8 sheet for $25, and filling in the seams with grout/cement and possibly painting or maybe getting the color impregnated board if I can find it, instead of using stucco.
Should give that "solid" look on the approx. 500 SF of the front of my upcoming house where the design calls for stucco. This would be directly up against foam board sheathing, and just bolt right on. Any reason not to do this, or tips on how to do it right? Don't think I can afford the stucco on my budget, plus it supposedly cracks pretty bad around here.
wesc is offline   Reply With Quote
Old 03-21-2008, 10:47 PM   #2
Rewards Points: 5,336
Sorry, that plan is doomed to failure. Why don't you go to the Hardie Website for the recommended use of the product you want to use. The success of the project is dependent on proper use, not your budget.
Ron
Old 03-22-2008, 08:20 AM   #3
Been to the site, couldn't figure out. In fact it didn't mention their textured board anywhere. How about that's why I ask the question here before I do it?
Couldn't figure out if it was supposed to be siding, or for only interior apps. It's made of the same stuff that hardi-paneling is made of (at least I thought). They have it at HD but can't find any info on it.
Old 03-22-2008, 08:39 AM   #4
Hmm, yep, they do make it. Don't know if it's the same thing they had at HD, but CertainTeed has 4x8, 4x9, or 4x10 sheets of it. Page 15. Is this "Doomed to Failure"? Lol.
http://www.ilevel.com/literature/WB%20801.pdf
Old 03-22-2008, 09:46 AM   #5
Rewards Points: 150
Don't do what you are thinking. Properly installed stucco won't crack too much.
kgphoto is offline   Reply With Quote
Old 03-22-2008, 12:43 PM   #6
Thanks for the info. I might just have to figure out how to install stucco.
Hardie backer board DXS General DIY Discussions 2 03-17-2009 05:40 PM
Hardie Board Siding and Wind gordo409 Building & Construction 2 07-10-2007 06:00 AM
Hardie Board Vs.....? tattood General DIY Discussions 2 08-10-2005 09:26 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
