Hardie Board Rust Staples In Remod Wood Frame House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-25-2014, 01:36 PM   #1
Rewards Points: 271
Hardie board rust staples in remod wood frame house
I al looking at a 2 story house in central eastern Florida near the ocean. The house was rehabbed and they did a pretty good job. I have lived in CBS (concrete block) homes most of my life. The area got hit about 10 years ago but the homes in the community held up well. Most are CBS or frame and stucco.
I am looking at this home that has been rehabbed. Google street pictures actually has it stripped down to the wood. The rehabbers screwed up on a second story pation deck using 1/4 or 1/2 inch boards and the deck is already warping due. So I am concerned these guys may not have been that sharp.
They put Hardie board on the outside over the wood frame. The roof is a metal roof. They painted the Hardie board but I noticed a few of the staples through the paint and I am seeing a little rust.
My spouse likes the house but I am worried. If these staples start rusting out then I am concerned. I had a deck dock built at the house I am selling and they used stainless steel screw. Shoe I be worried about the Hardie board? Thanks.
FrankL is offline   Reply With Quote
Old 05-25-2014, 01:59 PM   #2
Rewards Points: 271
Checked on Hardie board and it says no staples and corroision resistant fasteners. I am not sure if I need to contact the building inspector for the city to see if he has notes or the house inspector before buying.
http://www.jameshardie.com/pdf/insta...plank-hz10.pdf
Old 05-25-2014, 02:17 PM   #3
AHH, SPANS!!!
Rewards Points: 1,166
hardie is blind nailed, meaning you do not see the nails they are located below the lap of the piece above. if you see nails then they are probably trim nails or staples tacked at the seams to help hold the seams together. unless they face nailed the hardie, I've seen that before mostly on repairs where hardie is fit back into masonite
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
FrankL (05-25-2014)
Old 05-25-2014, 04:11 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
HOLD ON!
Let's clear-up something. Was Hardiebacker shower board used or was Hardie lap siding used? They are two entirely different products with different uses made by the same company.
XXX
Old 05-26-2014, 02:26 PM   #5
Rewards Points: 271
Originally Posted by Bud Cline View Post
HOLD ON!
Lap siding.
Board and Batten wood siding Knucklez Building & Construction 39 11-07-2008 10:38 AM
Repairing wood siding next to a door frame... Beth777 General DIY Discussions 7 07-22-2008 08:56 AM
Add-on wood furnace in a small house? Jim Dam HVAC 1 06-24-2008 01:48 PM
Hardie Board Siding and Wind gordo409 Building & Construction 2 07-10-2007 06:00 AM
Hardie Board Vs.....? tattood General DIY Discussions 2 08-10-2005 09:26 PM
