Hardibacker Siding As A Shed Roof? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-26-2012, 02:46 PM   #1
Hardibacker siding as a shed roof?
I have a 8x12 shed that is constantly shaded. In the last 4 years the wood under the shingles has rotted and it's sinking fast. I was wondering if Hardibacker siding must be installed vertically only or if I could use it on the shed roof which has slight angles. Also does anyone know if Hardibacker siding is mold and mildew proof? This area is so shaded that moss grows between the tufts of grass.
Tomboy123 is offline   Reply With Quote
Old 04-26-2012, 03:05 PM   #2
cortell's Avatar
Rewards Points: 504
Anything with less than a 2:12 roof shouldn't have any sort of lapped roofing (shingles). Such a roof needs to be treated like a flat roof. You said "slight angles" so I don't know if yours is in this category.
Let's assume it isn't. I absolutely would not use hardie siding material (I assume you didn't mean hardibacker, since that's not even siding). Use asphalt shingles. If your roof is between 2:12 and 4:12, you need to double up on the roofing felt.
Search the internet for how to install asphalt shingles. There's numerous steps, but it's very much a DIY project if you're not too afraid of heights.
cortell is offline   Reply With Quote
Old 04-26-2012, 06:23 PM   #3
Rewards Points: 12,808
Shallow pitch then just go with metal roofing.
Remove what's there now for shingles and sheathing and just install 1 X 6 pine at right angles of the rafters every 16" and install the metal right over it.
Old 04-26-2012, 08:12 PM   #4
Thanks guys! I've been thinking about corrugated metal roofing from when mine first started to go bad but I can't find it anywhere around here. I haven't checked Agway yet, maybe I will, or stop at a farm and ask them where they got theirs. Home Depot used to have corrugated fiberglass roofing which I thought would have been ideal, but they don't carry it anymore. I think I'll go back to the metal idea or hunt harder for fiberglass. If you have any ideas of places to get it I'd appreciate it.
Old 04-26-2012, 08:14 PM   #5
Lowes, Home Depot, any lumber yards will have metal roofing. It may be 5 V but it will work fine.
Vinyl siding above pitched porch roof - how to secure the bottom of the siding? joshoc Building & Construction 21 10-09-2010 01:42 PM
New siding before new roof? Dbn107 Building & Construction 4 04-07-2010 11:24 PM
Question: Altering One Side of a Gable Roof to a Shed Roof willcmjr Roofing/Siding 11 09-17-2009 05:32 PM
Where porch roof meets wood siding Trish99 Roofing/Siding 14 07-16-2009 09:31 AM
Siding where roof meets wall WSC Building & Construction 3 06-07-2009 01:18 PM
