Old 10-03-2010, 04:58 PM   #1
hardiback or durarock for basement floor
trying to gauge what to use for a cement basement foundation to lay down some tiles. I've read some threads here about the silliness of having a underlayer on top of cement for tiles but i figured it'll avoid having to do some leveling work (overall it's pretty smooth). Anyhow, any advice for basement with durarock or hadiback? i've used hardiback before for a kitchen tile build and have found it extremely easy to cut. never used durarock before but it looks like it could be a pain. thoughts welcomed thanks
vote4Pedro is offline   Reply With Quote
Old 10-03-2010, 07:37 PM   #2
i just used durarock in my bathroom. it was easy enough to cut. don't bother with one of the special scoring knives...just use a utility knife, and replace the blade a little more frequently than you would with dry wall.
as far as a basement floor goes, it would be a lot cheaper to use a leveling compound over the existing cement. and the cement board is not going to "level" out the floor, although it will provide a more uniform/smooth surface. but the combination of a leveling compound and thinset should be enough to overcome any uneven cement in your basement,....i would think.
1910NE is offline   Reply With Quote
Old 10-03-2010, 08:19 PM   #3
well.. i'm putting durarock or hardiback there just so in case i have a change of heart and go wood. I already have the basement measured with the recent round of rain to determine that it holds up pretty well against moisture. what's the major diff between durarock and hardiback anyhow.
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 11:23 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
