Hardi Plank (Preprimed HZ5) Questions??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 11:14 AM   #1
Learn2Build's Avatar
We just got our siding done this Saturday night before the storms came rolling in through Des Moines, IA and now I have some questions & concerns about the install and siding before I move on to finishing it completely.
#1
I noticed that when some planks got nailed up (blind nailed) in various locations they are kinda tight against inside/outside corner trim. Almost all of the siding is good with the 1/8" gap that the James Hardie Best practices guide recommends at these locations. So, will this be a problem, since I am unsure about the contraction/swelling properties on Hardi Plank? If so should I attempt to cut the end of the mounted planks to create the required gap?
#2
We got fairly heavy rain from Saturday night until today (Monday) with a continued chance of it all week long. I didn't get to caulk when we finished due to the rain. How soon can I caulk with Vulkem after the rain lets off? I am worried about trapping moisture behind the siding if I caulk to soon or possibly having it wash out.
#3
Once I can caulk, should I prime the Hardi Plank since it's preprimed? BTW I do intend to blast off any dirt or cutting dust before I prime/paint.
Learn2Build is offline   Reply With Quote
Old 07-05-2010, 04:12 PM   #2
kwikfishron's Avatar
Rewards Points: 594
I wouldn’t worry about it. Hardi expands and contracts very little. Since you installed it in summer in IA. I’d expect more contraction than expansion from here on out.
As soon as everything is dry to the touch. Any water that may have got behind the siding will dry out.
That’s a good question, Hardi says no as long as you paint within 5 mo. (I think). I haven’t seen any problems that would make me think otherwise but I know two different painters that “do prime” the pre-primed Hardi before they paint.
kwikfishron is online now   Reply With Quote
Old 07-05-2010, 08:07 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
i actually think you get a better cement job doing the painting after installation,much more custom look to me personally
Tom Struble is offline   Reply With Quote
Hardi plank - staining vs painting acdrey Building & Construction 36 03-22-2015 10:53 AM
Can I still caulk hardi plank after a rain vbflmt Building & Construction 3 09-14-2009 07:23 AM
Hardi plank installation - distance between butt joints? Scuba_Dave Building & Construction 25 07-21-2009 12:01 PM
hardi plank jwms Building & Construction 5 05-16-2009 11:07 PM
Replacing Cedar Lap with Hardi Plank rodss Carpentry 7 02-19-2009 06:27 PM
