Hardi Board Trim Installation Tips?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 06:51 PM   #1
Hardi Board Trim installation tips??
Wanting to trim out exterior side of my windows with a somewhat smooth trim. Smooth Cedar in the thickness I want too expensive. Smart trim too coarse of a pattern. Exploring the option of using 5/4 x 4" Hardi Trim. Never worked with it before. Bought a piece, and the appropriate blade today to experiment. Don't know how long the blade will last, but the first cut was like butter, and much less dust than expected.
My question is this. Does anyone have any tips on installing? The website isn't as descript as I'd like. Either that, or I'm not reading/navigating it right. I find no mention of nail size or if I should predrill.
I drove a couple 10d galv into it, and wasn't impressed. Stress cracks, and some mushrooming. Afraid to predrill it loose. Wondering if the best approach is to drill a size smaller than nail?? Are 10d's too big?
This stuff is HEAVY, so I want it to be very secure.
Windows and house are wrapped, so I can't use adhesives.
Thanks for any comments.
Jules
You can't fix stupid.....
JulesB is offline   Reply With Quote
Old 03-24-2011, 01:18 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
Hardie now has a trim tab detail
http://www.jameshardie.com/pdf/insta...im-nt3-hz5.pdf
Tom Struble is offline   Reply With Quote
Old 03-24-2011, 09:21 AM   #3
Originally Posted by tomstruble View Post
Tom,
I've read this pdf. The J Hardi Trim sold locally isn't groove back. May not make a difference, and it would be preferred to attach without face nailing. I installed one window yesterday by facing it, and it was tedious at best. pre-drilling, and center punching each nail.
Will attempted to contact JH directly today.
Thanks for chiming in.
Jules
Old 03-24-2011, 09:27 AM   #4
I guess I could open my eyes though and read it all........
HardieTrim
NT3 boards can also be installed in a more traditional fashion with finish nails. Use
minimum 16 ga. 2" galvanized finish nails spaced at 16" o.c. to attach the trim.
assuming other styles can be installed the same.
Old 03-24-2011, 10:13 AM   #5
Were just finishing up a job with hardi trim, 5/4x4 up to 5/4x12. We face nailed it with 2-3/8" ringshanks with a framing nailer, our coil nailer wouldnt sink the nails. Your right its HEAVY.
RTRCon is offline   Reply With Quote
Old 03-24-2011, 07:14 PM   #6
the same detail can be used on any type of solid trim,remember you will also be caulking the trim to the hardie and also around the window,a good polyureathane or eqivilent caulk which really helps hold the trim in position too helping to minimize the amount of fasteners you need....within reason
Old 03-24-2011, 08:22 PM   #7
I can't imagine lugging a X12 up to a gable peak......ugh.
Old 03-24-2011, 08:28 PM   #8
I do like the fastener concept, though I've never seen it before. I experimented with "attempting" to drive a couple 16d galv finish nails, as per the sites suggestion. That's a joke.
In my particular application, I'm simply wrapping my windows. Eave trim and lower band are out of smooth cedar. Solid area to be stucco.
Old 03-24-2011, 09:05 PM   #9
post some pics when you get a chance
Nailing Hardi board siding steelpony5555 Building & Construction 10 02-13-2011 08:48 PM
MW Vinyl windows w/ JChannel + Hardi Board Siding - Proper Flashing? jboeckler Building & Construction 1 09-20-2008 03:55 PM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 04:22 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Concrete board installation HELP! irlizard Flooring 4 07-28-2006 09:35 PM
