Hardey Board Fix - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-05-2010, 05:01 PM   #1
hardey board fix
when we built our home, we used the Hardy Board 4x8 with the "stucco" finish. I really don't like the seams and wanted to start stucco'ing the house and use stone accents for windows, corners, etc. I have been told that I could simply tack the wire and start scratch coating, since the hardy board is cement. Do you all agree?
momb5 is offline   Reply With Quote
Old 06-05-2010, 07:32 PM   #2
kwikfishron's Avatar
Rewards Points: 82
With 4x8 Hardi siding you run bats on the seams. Hardi is not T&G like 4x8 wood siding so the bats also help the keep the water out and cover the ugly seam.
I know this doesn’t answer your question but you might want to consider what your 4x8 Hardi job would look like if it was finished.
kwikfishron is online now   Reply With Quote
Old 06-06-2010, 08:34 AM   #3
Concrete & Masonry
Rewards Points: 468
I wouldn't treat it any differnet than sheating. All it sounds like you're saving with this approach is the WRB layer(s), tar paper, Tyvek, etc.....
Make sure to use long enough roofing nails to penetrate the STUD at least 1". We always use 1/2" wide staples for this, but I don't see the staples drivign through Hardie. Don't forget to extend the hose bibs, electrical boxes, etc... as well.
jomama45 is online now   Reply With Quote
installing backer board over particle board bob mac Flooring 6 07-16-2013 04:15 PM
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 11:50 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 10:41 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 11:03 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
