Hard Cut Nails - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-10-2012, 08:35 PM   #1
Rewards Points: 1,622
Hard Cut Nails
I have a 70s house and the furring strips were attached to the concrete block walls with hard cut nails.
How did they attach the hard cut nails through the wood to the blocks?
Was it just using brute force? Pound them in with a hammer?
miamicuse is offline   Reply With Quote
Old 11-10-2012, 09:13 PM   #2
yep you just pound them in
Old 11-10-2012, 10:59 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
wasn't that difficult, just had to make sure you hit the nail right or a corner could come flying off .....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 11-10-2012, 11:52 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 292
When driving that type of nail, don't hit it that last lick or it will bounce the wood back loose.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-11-2012, 05:58 AM   #5
Rewards Points: 3,130
In my experience, you need something like a driller's hammer.
Old 11-11-2012, 08:06 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
a smooth accurate hammer swing along with safety glasses and exact mortar joint placement is how those nails are driven. If the hard cut nails need to come out later it is somewhat better to bend and break them than to pull them...
hand drive is offline   Reply With Quote
Old 11-11-2012, 02:13 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 292
No disrespect H D, I never had any luck with a cut nail holding in the mortar joint. I didn't care for cut nails in blocks at all, I always used screws.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
hand drive (11-11-2012)
Old 11-11-2012, 10:21 PM   #8
AHH, SPANS!!!
screws with anchors are even better! But just starting out doing construction type work I worked on thousands of houses and did what the boss said and if it meant driving cut nails so be it.
Painting prep - exposed/previously caulked nails jmoe24 Painting 1 04-16-2011 09:08 AM
Cut nails not holding strong in concrete lateralus Building & Construction 32 01-07-2011 09:36 PM
*PICS* Advise Needed: Exposed Nails and Bad Gutters Mike06271980 Roofing/Siding 8 10-13-2010 07:35 PM
rusty siding nails carniture Building & Construction 1 09-23-2010 01:38 PM
sinking fluted masonry nails ajtool General DIY Discussions 3 09-02-2010 03:58 PM
