Hanging Soffit Using Plastic Board Fascia - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2010, 08:15 AM   #1
Rewards Points: 562
hanging soffit using plastic board fascia
I am putting all new soffits on a house without any now (extending the rafters for 'some' overhang) probably 12 or 18" or so. Was going to use Certainteed plastic 1X4 or 1X6 as fascia board cause I like the look and durability.
So I have no fascia cover to cover outside edge of actual vented soffit material. Do I use a "F" channel on both sides, screwed fast to back side of fascia??? If so how do you get soffit panels in there?
What other way to cover ragged cut edge behind fascia board??
4just1don is offline   Reply With Quote
Old 09-03-2010, 02:56 PM   #2
Rewards Points: 156
I used 2, F channels, one on the house wall and the other on the back edge of the fascia board. My soffits were 12" long and you can bend them slightly to get them up in the channels, your soffit panels should be slightly shorther than your channel to channel span for expansion. If you have a lot of soffit panels to install then I would not install one F channel at an end of the house and then you can easily place your soffits up in the channels and slide them down. Pictured is my job, but I used vinyl cladding over my fascia boards so it partially covers my one F channel as it sits ontop of the lip.
creamaster is offline   Reply With Quote
Rotted Soffit and Fascia boyfly Carpentry 1 05-08-2009 10:12 PM
Hanging Kitchen Cabinets from soffit...no backwall ronp Carpentry 6 12-15-2008 01:45 PM
hanging a dart board JAVAMAN General DIY Discussions 13 01-07-2008 07:52 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
