Old 03-13-2012, 11:52 PM   #1
carmel64's Avatar
Hanging Roof shingles..
Can anyone tell me if this is normal to have the roof shingles hang off this way after installling hardie lap siding? It seems to me that they should sit flush to the very end of the siding. Will this likely cause any damage to the shingles?
carmel64 is offline   Reply With Quote
Old 03-14-2012, 03:14 AM   #2
JOATMON
ddawg16's Avatar
I can't get your pic to open up larger....
Just how far do the shingles stick out? 1/8-1/4" is about right....an inch or more would be an issue...
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
carmel64 (03-14-2012)
Old 03-14-2012, 09:35 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Sorry, cannot see a thing in the way the picture is formatted (really small).
Roof shingles, in areas not prone to hurricanes, standardly overhang the aluminum drip edges, which in turn overhang the fascia trim boards. This allows rain water to drop free and clear of (not run-down) the wood trim, or other siding material that are installed on the structure.
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
Old 03-14-2012, 10:16 AM   #4
One issue will find happening soon will be the ends of the panels where it's in direct contact with the shingles will start to bubble up and the finish will fail.
It was suppost to be at least 2" away from the shingles, and the end cuts needed to be sealed with paint.
I use vinyl 1 X 4 lumber, a strip of Z moulding, a strip of vinyl lattis to kick out the siding, then the siding to prevent premature failure.
May want to Google the install manual on Hardee lap, it's even shows a picture of what I'm talking about.
Old 03-14-2012, 10:20 AM   #5
carmel64's Avatar
So my concern should be more on the siding than on the shingles? I just wasn't sure if the shingles that hang over will be compromised in any way? Thank you for your kind response!
Old 03-14-2012, 11:17 AM   #6
There is information in the Hardie Installation Link that addresses and diagrams - that a gap should be left between the siding and the roof shingle surfaces on Dormer sidwalls configurations (during the siding installation process).
Please refer to page 2 in the link: http://www.jameshardie.com/pdf/insta...eplank-hz5.pdf
Don't know if this helps you......
- Build Well -
Old 03-14-2012, 11:22 AM   #7
We still have no idea what you mean by the shingles are hanging over. Hanging over what?
They should hang over the edges of the roofs edges.
Old 03-14-2012, 11:26 AM   #8
carmel64's Avatar
Okay, I think you just answered my question...it's okay to then to have shingles hang over the roof edge. Thanks!
Tags
roof corners, roof damage
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing 9 09-04-2011 10:29 AM
Asphalt roof shingles vlloyd1028 Roofing 3 05-11-2011 06:42 AM
Painting New Roof Shingles to match old ones? Lgarced Painting 0 03-25-2010 09:46 PM
Storing shingles on roof GerryinBelleRiv Roofing 1 09-03-2009 08:13 PM
Improperly installed roof ktpersh Roofing 1 05-15-2008 07:57 PM
