Old 09-26-2010, 04:33 PM   #1
Hanging really heavy mirror
Does anyone have any experience in hanging a really heavy mirror, 70 lbs. I want to make sure it is safe. Any suggestions would be apreciated. Thanks guys,
beech is offline   Reply With Quote
Old 09-26-2010, 05:34 PM   #2
just be sure you hang it on & w/something that can hold that weight,,, nominal shear strength of fasteners ( hooks ) should be dble the load's weight,,, this means either a good size'd nail OR screw into the 2x4 behind the drywall
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 09-26-2010, 06:18 PM   #3
HD/Lowes did not have the hardware I needed to safely mount a similarly large mirror and picture. I bought a flat strip of metal 1 x 24 x 1/8 and made two 8 inch strips, drilled 4 holes on each strip. I used 3 screws to install each strip on the back of the mirror and connected the remaining hole with metal wire. Find the stud and use a good size threaded L-shaped hanging screw or 2
aggreX is offline   Reply With Quote
Old 09-26-2010, 06:35 PM   #4
thanks guys
Old 09-26-2010, 07:57 PM   #5
framed mirror or just mirror?
wnabcptrNH is offline   Reply With Quote
Old 09-26-2010, 09:46 PM   #6
framed but it might just be particle board.
Old 09-26-2010, 09:53 PM   #7
I would just make sure you screw into studs. I wouldnt trust those drywall hangers.
Old 05-11-2011, 11:33 AM   #8
use zbar hanger for any heavy item .is a strip aluminum and has holes every 4".you can serch it on line.or find it in zbarhanger.com
carina is offline   Reply With Quote
The Following User Says Thank You to carina For This Useful Post:
beech (05-11-2011)
Help to hang heavy mirror robwallis Interior Decorating 2 08-17-2010 06:01 PM
Hanging a Heavy Mirror frapha1 General Discussion 6 01-03-2010 12:21 PM
hanging a mirror ghudspeth Building & Construction 2 12-30-2009 08:04 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 02:03 PM
hanging a mirror mina General Discussion 1 09-09-2007 10:41 PM
