Hanging A Pendant Light From Center Of Vaulted Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2013, 09:49 PM   #1
hanging a pendant light from center of vaulted ceiling
We have 3 pendant lights to hang over the kitchen island. We have just recently vaulted the ceiling, measured out all our lighting......but in order to hang the middle pendant light where I want it, it is exactly on the center, where the two slopes meet at the top. How do I hang it there, without a big ugly gap where the plate is supposed to fit against a flat ceiling??
soberjulie is offline   Reply With Quote
Old 07-11-2013, 10:28 PM   #2
in some of the houses i use to work on they would cut a piece of 2x10 or 2x12 or build a box to make a flat spot for the fan or light to mount to.
The Following User Says Thank You to DannyT For This Useful Post:
MTN REMODEL LLC (07-11-2013)
Old 07-11-2013, 10:35 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,408
Because slopes vary so differently, you won't find a receptical box to fit.
Just make a box out of 3/4 pine, or whatever, that gives you a level mount for the fixture.
Sorry, I can't draw, but it is nothing but a box appriapriately slopped to meet your ceiling slopes.
Make it, router/bevel the edges, however decoratively you want it.
MTN REMODEL LLC is online now   Reply With Quote
Old 07-12-2013, 12:05 AM   #4
Rewards Points: 1,010
This might work, depending on the slope of your ceiling.
http://www.homedepot.com/p/Arlington...5#.Ud-AREGG2So
spaceman spif is offline   Reply With Quote
Old 07-12-2013, 10:22 AM   #5
AHH, SPANS!!!
Rewards Points: 1,166
the pre made boxes work best for a 12/12 pitch roof angle. on a lot of them we make a box out of 2x stock with the angles cut and install it and the electrician uses a pancake fan box mounted to our box with long screws and the drywallers drywall the box with finished corner beads. another way is to finish it out with 1x material.
hand drive is offline   Reply With Quote
Old 07-12-2013, 11:00 AM   #6
Never posted a pic before.... so just learning.... these are just an example out of my gameroom and sunroom.... they are on a hip.... and obviously a gable/ridge is quicker. I happened to do them in natural... but often where they are not a decorative element (like maybe your pendents) just do them in a planed pine and paint them to blend into the ceiling.
Good luck
Best
Peter
hanging a pendant light from center of vaulted ceiling-canopy-boxes-001.jpg   hanging a pendant light from center of vaulted ceiling-canopy-boxes-002.jpg   hanging a pendant light from center of vaulted ceiling-canopy-boxes-003.jpg   hanging a pendant light from center of vaulted ceiling-canopy-boxes-004.jpg
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
hand drive (07-12-2013)
Old 07-12-2013, 11:05 AM   #7
AHH, SPANS!!!
wow! that is an awesome ceiling. thanks for posting!
The Following User Says Thank You to hand drive For This Useful Post:
MTN REMODEL LLC (07-12-2013)
Ceiling Fan Light Problem loftezy Electrical 13 12-19-2015 08:57 PM
Diagram for 3 way ceiling fan light switch Aurora65 Electrical 22 11-27-2012 10:11 AM
Spiral pendant hanging light (good bulbs not illuminating) jbarrick Electrical 1 10-03-2012 08:17 PM
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 09:32 AM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 04:06 PM
