Hanging A Large Wooden Gate. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-06-2012, 07:54 PM   #1
HomeFixer
Hanging a large wooden gate.
I want to convert a pre-fabbed piece home depot 6' x 8' fence section to an inward-swinging gate. The hinge side will anchor against a garage for support. Because the support side is slightly down from the latch side the bottom will be trimmed upward to maintain ground clearance. Should a get a metal anti sag support kit, and what other recommendations might there be?
Joe Vokt is offline   Reply With Quote
Old 01-06-2012, 08:00 PM   #2
A Little Of Everything
Rewards Points: 1,364
Originally Posted by Joe Vokt View Post
I want to convert a pre-fabbed piece home depot 6' x 8' fence section to a fence. One side will anchor against a garage for support. What other issues should I be aware of?
The way a section of fence is constructed will not, without modification, be a good gate. You'll need to install cross-bucks. Heavy hinges are a must. And I'd either put a wheel on the outside end of the gate, or install a cable from the outside end to the garage - about 8' off the ground.
DrHicks is offline   Reply With Quote
Old 01-06-2012, 08:06 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Try just running a diagonal 1x (obviously from the lower hinge up to the top of the swing side) and see how it holds up before dumping money in it for cable and turnbuckles, etc. You'de be amazed what one diagonal brace can do.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-06-2012, 08:09 PM   #4
HomeFixer
Cool
I have some very sturdy thick hinges. There are three cross members on this
piece of fence. So three hinges seems like a good idea. Where would the connection points for a proposed 8' cable be? I'm not sure I understand how that would connect to a moving gate. I thought of the wheel idea also but the latch side is too uneven for that.
Old 01-06-2012, 08:19 PM   #5
HomeFixer
Cool
A "1x" would be a 1" thick board nailed across the back of the three cross members diagonally from the lower hinge side to the upper swing side?
If so, how wide should that board be? The thing would be about 10 or so feet long.
Old 01-06-2012, 08:19 PM   #6
Disabled wood vet
titanoman's Avatar
I think he's just saying hook a cable from the upper outside of the gate to high up on the garage above the hinges. That would work pretty good (I would still run a couple diagonals)
Old 01-06-2012, 08:20 PM   #7
Disabled wood vet
titanoman's Avatar
A 1x6. Maybe one on the inside and one on the outside.
Old 01-06-2012, 08:39 PM   #8
HomeFixer
Cool
The original gate section to be replaced was about 4 feet wide and about 4 feet high. It was anchored into to a stucco wall against a 4" x 4" x 5' member with two anchor bolts into the wall. With the larger, heavier proposed gate should there be another anchor bolt into the stucco? Would that remove the need for a wall cable onto the gate?
Old 01-06-2012, 08:44 PM   #9
Disabled wood vet
titanoman's Avatar
Definitely.
Old 01-06-2012, 08:45 PM   #10
kwikfishron's Avatar
Rewards Points: 172
You need the wheel.
There’s no way you’ll get the prefab 8’ section of fence not to sag without it.
kwikfishron is online now   Reply With Quote
Old 01-06-2012, 10:58 PM   #11
Disabled wood vet
titanoman's Avatar
Originally Posted by kwikfishron
You need the wheel.
He can't use a wheel. The terrain has too much up and down.
Try the diagonals, and secure that post real good to the garage.
Diagonal bracing is holding up big houses everywhere.
The Following User Says Thank You to titanoman For This Useful Post:
mae-ling (01-07-2012)
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Need ideas for large, multi-space living room D-Lew Interior Decorating 2 01-03-2012 01:26 PM
Large hole in wooden support beam a problem? mephisto Building & Construction 5 07-18-2011 12:36 PM
Hanging a Heavy Mirror frapha1 General DIY Discussions 6 01-03-2010 12:21 PM
hanging weight off of tji beams?? summer76 Building & Construction 2 04-14-2009 03:00 AM
