Hanging Ladder On Vinyl Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-15-2012, 02:05 PM   #1
Rewards Points: 590
Hanging ladder on vinyl siding
Once my shed is finally built I want to hang my large ladder on the side of it. The ladder is 12' long at its shortest which is why I want to keep it outside to save space. My question is, how can I mount hooks to the side of the shed with vinyl siding? Is there a certain type I should look for?
Thanks again
nikeman is offline   Reply With Quote
Old 03-15-2012, 02:42 PM   #2
Rewards Points: 152
I would set a couple of posts, treated 4x4's or round wood fence posts, or even metal T posts for that matter, along side of the shed, and hang it from them, rather than punching holes in and having it rub against the siding.
Old 03-15-2012, 02:59 PM   #3
Rewards Points: 590
What if I got the contractor to do it for before installing the siding? Same situation right? The posts sounds like a good idea.
Old 03-15-2012, 03:19 PM   #4
Rewards Points: 14,312
Vinyl siding has to be able to expand and contract, that's why there's elongated holes for the nails. Nail it tight and it buckles.
Rust on the side of the building from the fastners, change of leaks, poking hole in in the siding. All reasons not to do it.
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 10:23 PM
Removing vinyl trim around entry door without breaking vinyl siding 2vets Building & Construction 1 10-18-2010 10:28 AM
heat vents for vinyl siding skychief Building & Construction 3 06-11-2010 08:37 PM
Replacing Wood Siding WIth Foam Backed Vinyl xludan Building & Construction 1 05-21-2009 06:27 PM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 03:03 PM
