Hanging Kayak Storage Rack On A Lally Column? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 08:33 PM   #1
Rewards Points: 16
Hanging kayak storage rack on a lally column?
I am trying to find a place in my basement to store my kayaks. Unfortunately, all the walls are out since they there is something next to each one of them (gas meter/sewer pipe, heaters, washer/dryer/stairwell, closet). However, there are two lally columns in my basement supporting the main beam - these don't sound hollow when I knock on them with a metal object, but they do vibrate a bit when I knock on them with my fist. I have a crazy idea to mount a sturdy piece of wood to the lally column, maybe a 2x8, using U-bolts, and then mount a kayak rack to the 2x8. Something like http://www.amazon.com/Malone-J-Dock-...8492607&sr=8-1 . Basically, create a pseudo-wall surface which would be attached to the column via U-bolts. The additional weight on the column would not exceed 100lb, though the rack/piece of wood would put some shear stress on the column. Now, the column is pretty thick (4" in diameter, I believe)... but is this a good idea? Can attaching something to lally columns possibly be against building codes?
whiskers is offline   Reply With Quote
Old 06-19-2011, 09:57 PM   #2
Rewards Points: 5,334
As long as you wrap the connection around the lally column and do not drill holes in it, you will be fine.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
whiskers (06-24-2011)
Old 06-24-2011, 05:56 PM   #3
Rewards Points: 16
Thanks for the reply, that's what I'll do then!
Need advise: Additional support for existing lally column vluzhko Building & Construction 6 05-17-2012 07:56 AM
removing lally column in basement jimnlinda Building & Construction 3 04-08-2011 01:29 PM
Weird Lally Column Issue After RI Flood Damage Lou Fancy Building & Construction 2 04-09-2010 10:47 AM
Tranferring load to basement beam and lally column cooperwd Building & Construction 3 08-17-2009 10:14 AM
Concrete patch for lally column footing? AllGoNoShow Building & Construction 6 10-21-2006 08:16 PM
