Hanging Exterior Steps Without Footer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 06:20 PM   #1
Rewards Points: 18
I have a two-level garden behind my house that needs a couple steps to go from the upper to lower level. I only need two steps, and the ground is very soft since it is planting mix, so digging deep for cement footers seems like a bad and unnecessary idea. The yardstick in the picture (attached) shows that the drop is only about 24 inches. The cinder block wall uses the 12" thick blocks and I can fill it with cement to strengthen it and provide a better anchor for any bolts. What would be the best configuration to hang a couple stringers from the wall without having a footer for them to sit on at the bottom? I believe a good anchor at the top, and a horizontal brace back to the wall at the bottom would suffice, but does anyone have a better idea? (The wall will eventually be covered with stone, with slate capstones, but they can be installed after the stringers so as not to interfere.)
Thanks in advance,
Wally
WallyB is offline   Reply With Quote
Old 06-21-2011, 09:22 PM   #2
Stay-at-home GC
Two beefy natural stone treads would look nice there. Bed them gravel and build your wall veneer out around them.
IMHO
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 06-22-2011, 12:48 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 304
Any type of steps you put there without a footing will settle after a while and they may not settle the same on all sides and will make the steps different margins from the top of the block wall. When figuring the steps you will need to take the thickness of the cap you plan to use on top of the blocks in consideration.
Anchoring back to the blocks will not work without a footing as the front edge of the steps will settle and the step against the blocks won't. Also if the steps are anchored too solidly, when there is settlement it could pull or break the blocks loose.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 06-22-2011, 07:04 AM   #4
Rewards Points: 5,336
.."the ground is very soft since it is planting mix, so digging deep for cement footers seems like a bad and unnecessary idea."
That's just the reason digging a footing is a good idea and necessary.
Doing it your way is a waste of time and money as it will fail pretty quickly.
Ron
B. Franklin 1759
Short Retaining Wall - Footer jkim8520 Landscaping & Lawn Care 3 06-03-2011 10:27 AM
Brick footer brknardo Building & Construction 0 09-18-2010 06:37 AM
How far from egress should I place a footer LarryV Building & Construction 7 08-27-2009 08:49 PM
Footer deere2440 Building & Construction 7 03-01-2008 08:54 PM
Undercut footer billinak Building & Construction 3 03-18-2005 06:34 PM
