Hanging Drywall - Vertical Or Horizontal? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-10-2010, 09:26 AM   #16
Pro
Nostco's Avatar
Originally Posted by johnrem View Post
If I can get the 10' and 12' board into the basement,I will hang horizontal. However,many times the stairwell prevents us from getting much more than 8' board down.In that case,the longer walls get hung vertical.
For what reason? There's no logical advantage, you're just making the next step more difficult for yourself.
Nostco is offline   Reply With Quote
Old 04-12-2010, 08:38 AM   #17
yummy mummy's Avatar
Rewards Points: 1,016
nostco
Where in Toronto do you do most of your work?
I am also from T.O., and in my area there is a lot of construction going on.
yummy mummy is offline   Reply With Quote
Old 09-14-2010, 01:13 PM   #18
Handyman
Rewards Points: 512
I hope Willie is still subscribed to this thread
I clicked on your link about the butt-board construction. Looks like a great idea! The poster board it mentions...is that just regular bristle board, like kids use at school? Doesn't seem like that would create enough of a recess...or does it?
canadaclub is offline   Reply With Quote
Old 09-14-2010, 02:21 PM   #19
liscenced electrician
Rewards Points: 538
ive always thought you hang horizontal so that you don't have one big long seam all the way down a stud. Staggering the sheets horizontaly makes it so the studs can't move side to side
jimmy21 is offline   Reply With Quote
Old 09-14-2010, 03:04 PM   #20
Old School
Willie T's Avatar
Just keep it closer to 1/16" than 1/8". The 1/8" thickness of poster board will force too much of a bend in such a short distance. The paper surface won't take that, and the screws will cut through.
Willie T
Old 09-14-2010, 06:48 PM   #21
Handyman
Rewards Points: 512
Thx WILLIE..I'll give it try
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 09:50 AM
Drywall - Horizontal or vertical slinku2020 Drywall & Plaster 27 04-08-2010 12:40 PM
Hanging drywall vertical on basement wall ? Oxymoron Drywall & Plaster 4 02-04-2010 09:58 AM
Hanging drywall Question avtck Drywall & Plaster 6 01-05-2010 06:21 AM
horizontal or vertical plywood sheathing. Clutchcargo Building & Construction 6 07-12-2009 01:51 PM
