Hanging Drywall Basement Ceiling From Engineered Wood I-beam Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-09-2008, 02:08 AM   #1
Hanging drywall basement ceiling from engineered wood I-beam joists
Are there any issues/re-inforcement needs when hanging a drywall ceiling in the basement from engineered wood I-beam floor joists?
ja_trusty is offline   Reply With Quote
Old 10-09-2008, 05:26 AM   #2
the Musigician
DangerMouse's Avatar
those things scared me when i first saw them. still do. google--> Collapse Dangers of Engineered Wood Beams <--for more info.
maybe a real lightweight drywall would be a bit more firesafe? idunno. i'll stick with 2x.
DM
Old 10-09-2008, 06:30 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
No, none what-so-ever.
- Build Well -
Old 10-09-2008, 06:58 AM   #4
Rewards Points: 150
No issues. Think about the rest of the house. Is the first floor ceiling made from the same engineered materials?
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 10-09-2008, 07:44 AM   #5
Registered User
Termite's Avatar
Agreed, no issues with the application of rock. It is common for multiple layers of rock to be applied to the underside of I-joists in multifamily construction. If the floor is solid and properly spanned, the added dead weight shouldn't affect the floor's performance.
As for the comments about the integrity of I-joists, pooey. They're a tried and true product, and are every bit as structurally stable as dimensional lumber, if not more. Since they are thin, a catastrophic fire will normally compromise them much faster than dimensional lumber joists, but proper firestopping and a sheetrock ceiling will protect them from all but the worst fires.
Old 10-09-2008, 08:07 AM   #6
Originally Posted by thekctermite View Post
...As for the comments about the integrity of I-joists, pooey. They're a tried and true product, and are every bit as structurally stable as dimensional lumber, if not more...
Double Pooey...
- Build Well -
Old 10-09-2008, 11:06 AM   #7
Thank you.
Thank you for the advice!
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
garage ceiling joists josh123 Carpentry 6 07-14-2009 11:07 PM
Exposed Wood Beam Ceiling repair - help needed abiseid Carpentry 6 01-04-2008 09:01 PM
Hanging a beam/rafter from a beam snmhanson Building & Construction 4 01-11-2007 10:37 PM
