Hanging Drywall Accurately - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-02-2009, 12:01 PM   #1
Rewards Points: 91
hanging drywall accurately
guys - I'm about to hang some drywall over a shower valve - the slower half sticks out of the wall a bit, the upper part does not. I'll need to cut two holes for both parts in two pieces of drywall. Any tips out there for cutting the holes in exactly the right spot?
mmhendrie is offline   Reply With Quote
Old 04-02-2009, 12:35 PM   #2
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Sure, numerous ones... some even involving lipstick! BUT BUT BUT, first lets find out why you are drywalling a shower... Are you just putting regular drywall in a shower stall or something?
J187 is offline   Reply With Quote
Old 04-02-2009, 12:59 PM   #3
Remodeling Contractor
Drywall over the shower head is okay. Drywall in the shower is okay if you will be covering it with Kerdi or Noble or CS.. or some waterproofing membrane.
To make a cut actually measure it with a ruler. Mark a line on the wall above the center of the shower head and one to the side. Easier to see these lines then to see the center while trying to read the measuring tape. You could extend these lines with a level and then measure at both far ends to the top and to the sides of the wall or ceiling to see if you are dealing with a square or out of square piece of sheetrock. Now make the same marks and measurements on the piece to cut and you will get it right.
Old 04-02-2009, 01:19 PM   #4
Rewards Points: 91
great - thanks for the tips. Yes, I should have realized not giving details when saying "drywall" and "shower" would have raised a few alarm bells, but fear ye not, schluter shower kit with kerdi in tow!
Old 04-02-2009, 03:09 PM   #5
yummy mummy's Avatar
Rewards Points: 1,016
I just had a laugh, because when I put up my drywall, I used lipstick......
A lovely hot red........
yummy mummy is offline   Reply With Quote
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 09:50 AM
Hanging soundboard and drywall Packer Backer Drywall & Plaster 5 10-10-2008 02:23 PM
Hanging Ceiling Drywall AFTER Wall Drywall? mfleming Drywall & Plaster 10 10-06-2008 03:32 PM
drywall hanging question steve1234 Building & Construction 3 05-08-2008 02:44 PM
Hanging Drywall Perpendicular To The Floor? DIYScott Remodeling 8 10-03-2007 08:47 AM
