Hanging Drywall On 18 Gauge Metal Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 09:16 PM   #1
Hanging drywall on 18 gauge metal studs
What type screws should(pls provide brand) I use to hang drywall on 18 gauge and should I purchase a special drywall screw gun for this task?
Any info would be appreciated!
Rbaker77 is offline   Reply With Quote
Old 07-08-2012, 09:34 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
fine threaded 1 1/4" drywall screws are for metal studs. a drywall drill (screw gun) 4,500 rpm can be found at any home improvement store. The trick with the screw gun is to set the tip (nose) so that the screw just barely penetrates the drywall paper but not to much, you can set the screw depth with the nose of the screw gun.
hand drive is offline   Reply With Quote
Old 07-09-2012, 09:36 AM   #3
Rewards Points: 77
with that heavy of gauge stud, i think you will need self tapping screws available where you got the studs.
bkvanbek is offline   Reply With Quote
hanging ceiling drywall in a basement charlie bob Drywall & Plaster 5 06-21-2013 12:30 PM
metal studs on drywall patg Drywall & Plaster 4 12-29-2011 02:56 AM
Using metal studs with a suspending ceiling MinerReb Remodeling 7 04-02-2010 06:57 PM
metal studs to build up attic floor Airborne180 Carpentry 6 12-13-2006 05:02 PM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
