Hanging A Blind In Metal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 06:37 PM   #1
hanging a blind in metal
I' m trying to hang a blind on my porch.It is stucco covered metal.What should I use?Lowes and Ace both told me to use plastic anchors but I can't drill through the metal.What should I use?
pattilou is offline   Reply With Quote
Old 04-05-2011, 02:24 AM   #2
Rewards Points: 1,092
How thick is the "metal", and what is behind it? A sharp, high speed steel drill bit, with proper pressure (and periodic, frequent oiling) will drill through any steel in a house. Put several nuts, or similar, over the drill bit as a "stop" so that the drill bit does not go in farther than you need it to. Start with a smaller sized bit, like 1/8" or 3/16", and don't push so hard you bend them. Wear eye protection, and plan on breaking a few.
The Following User Says Thank You to jklingel For This Useful Post:
pattilou (04-05-2011)
Old 04-05-2011, 04:44 PM   #3
Can I use plastic anchors? I don't know how thick the metal is. It is under stucco on the porch.
Old 04-05-2011, 05:14 PM   #4
SteelToes's Avatar
Rewards Points: 150
pattilou,
Just use self taping screws, having metal posts there in my opinion makes a job even easier
SteelToes is offline   Reply With Quote
The Following User Says Thank You to SteelToes For This Useful Post:
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 02:33 PM
Hanging Ballet Bars (commercial environment) in metal studs 504branchie Carpentry 12 03-29-2011 09:45 AM
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 06:54 AM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 02:03 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
