Hanging An Awning - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-08-2007, 11:21 AM   #1
hanging an awning
I need to hang an 18 foot motorized awning that ways about 125 pounds. the awning comes with 7 two fastener brackets. The awning will extend out about 10 feet and will be mounted about 10 feet off the ground.
Unfortunately, the side of the building is covered with stucco and behind the stucco is hollow concrete block.
Can you suggest the type of fastner and how you would recommend avoiding the joints of the block?
martin 1 is offline   Reply With Quote
Old 05-08-2007, 12:00 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
You may need to attach a ledger board first. If you do that then the brackets can be attached where they need to be. Attach the ledger into the hollows of the block with toggle bolts. Use wood screws into the ledger.
Brik is offline   Reply With Quote
Old 05-08-2007, 08:59 PM   #3
header board for awning
Thanks for the info. Thought about doing that but the manufacturer recommends against it but they wouldn't say why. I'll probably do it that way any way.
Thanks for your reply.
martin.
Hanging a Heavy Mirror frapha1 General DIY Discussions 6 01-03-2010 12:21 PM
Help hanging heavy punching bag from ceiling chrisski1991 Building & Construction 5 03-15-2007 08:46 PM
framing an awning...quick question sjrhome Building & Construction 7 12-03-2006 12:24 PM
Hanging towel bar in hollow core door. ERIK2173 Remodeling 1 02-06-2006 08:19 PM
Hanging a Wallpaper Border Nathan Painting 10 06-17-2005 02:19 PM
