Handrail Questions. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-21-2008, 07:59 PM   #1
wfischer's Avatar
Handrail questions.
While prepping this room for paint, it occurred to me that it might be a neat idea to replace this metal pipe handrail with something a little fancier. I was thinking of getting a 3' piece of handrail, some balusters, and probably making my own newel post (the pre-made ones are too expensive, and I'd just end up cutting them super short anyway). So, since I've never constructed a handrail before, I have a few questions:
The post and balusters would all be going down to the flat floor. Would I use a shoe rail along the bottom for this? If so, should the shoe rail go on top of the vinyl tile or directly attach to the subfloor, in which case I would tile around it?
How do you attach the handrail to the newel? the balusters to the handrail and the floor/shoerail? the newel to the floor? How should the shoerail (if used) be attached to the floor?
How many balusters would I need for my 3' section of rail?
I think that's it for now, thanks in advance.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape!
wfischer is offline   Reply With Quote
Old 03-23-2008, 01:38 PM   #2
wfischer's Avatar
anyone?
Old 03-24-2008, 10:47 PM   #3
BuilderRemodeler
This will be nice for you.
Your Local Lumber Supplier may have a break down of the steps needed.
Handrail Fastening, Newel Post Securing Anchors, etc... perhaps going there will be the fastest easiest method for you... some suppliers leave a tear off sheet with their products for detailed assembly instructions.
BuilderRemodeler
40 pages of useful Home Remodeling Charts, Home Addition Guidelines, Home Painting Tips, How to Determine a Deck Size and Build Your Deck Online! www.BrandsConstruction.com
www.HomePlansForFree.com One Story Ranch Detailed Free Home Plans
darylbrands is offline   Reply With Quote
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
Main/Sub/Garage Gen Backup Questions crecore Electrical 9 04-17-2006 07:31 PM
