Handrail Height - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 09:31 PM   #1
Handrail height
I have 39 inch balusters, what should the height of the handrail be?
russell60 is offline   Reply With Quote
Old 07-28-2012, 10:03 PM   #2
DIY staff
Rewards Points: 7,174
Stairs or balcony?
Also your location--codes vary by country--
oh'mike is online now   Reply With Quote
Old 07-28-2012, 10:44 PM   #3
In Alberta, Canada the code is 32"-38" for stairs to top of handrail measured from the edge of nosing.
For balconies is 36" if the balcony is not more than 6' dropoff below.
a 42" handrail is needed for balconies higher than 6'.
the carpenter is offline   Reply With Quote
Old 07-29-2012, 05:41 PM   #4
robertcdf's Avatar
Handrail or guardrail? a handrail is ONLY found on stairs. Typically 34" - 38" but your local codes may be different. A guardrail is fall prevention on flat surfaces (and next to stairs) and is usually MIN 36" - 42" depending upon your local codes.
robertcdf is offline   Reply With Quote
Old 07-30-2012, 08:28 AM   #5
Where I am it's 36" min if you have benches on the deck then the min becomes 48" with a max of 4" between balusters
utahjd1 is offline   Reply With Quote
What should be the height of wall? so roof pitch is 10 feet... vikasintl Roofing/Siding 2 07-04-2012 11:32 PM
ridge height calculation oxbow Building & Construction 19 01-14-2012 08:26 AM
How to frame new floor to match existing floor height taylor01 Carpentry 4 04-04-2010 09:59 PM
standard handrail height? Yeti Carpentry 15 06-23-2009 06:59 AM
Handrail height in Connecticut kjacob Building & Construction 11 10-01-2008 10:39 AM
