Half Wall With Barley Twist Wood Columns Load Bearing?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 07:33 PM   #1
urk
Half wall with barley twist wood columns load bearing??
Can someone tell me if the half-walls with the twisted barley wood posts in the attached picture are load-bearing?
urk is offline   Reply With Quote
Old 02-05-2012, 07:37 PM   #2
Rewards Points: 14,026
Look to flimsy to be supporting. Look under them to see if there's any piers or a block support wall in the crawl space or basement.
Look directly above to see if there's a wall lined up directly over them.
Old 02-05-2012, 08:12 PM   #3
urk
It's a tri level home with nothing but the attic above in that particular area.
Old 02-05-2012, 08:18 PM   #4
Then your left with checking out the rooms below down to the basement.
What's the plan? Thinking about removing them?
Keep in mind if you do your going to be doing ceiling and floor repairs.
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 03:39 PM
Load Bearing Wall??? please help shenmon Building & Construction 6 01-24-2009 10:07 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 07:43 AM
