Half Lap Sill Plate Join - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-05-2008, 02:04 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
Background... I have a sunroom that I wanted to add a level on to make it two stories. I tore the old sunroom down to get to the top of a fieldstone and cinderblock foundation so that I could fill the open cell cinderblocks with concrete. That's done with the exception of where the J-bolts will sit. I'm starting to rebuild this weekend (weather permitting). The sill plate that I took out was 4x8 and want to replace it with 4x8 PT.
For the outside corners, should I half-lap the adjacent sill plates and use 1 foundation anchor running through the lap join? Will this satisfy the 3.5"-12" distance from the ends of the sill for the foundation anchor on both sill plates? The sill plate that I took out was half lap join but there were no foundation anchors.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-05-2008, 02:36 PM   #2
Registered User
Termite's Avatar
No you shouldn't. You need a bolt on each plate within 12" of all corners and splices, but you probably can't get away with trying to kill two birds with one stone. I'd suggest two anchor bolts, each about 8" or 10" in from the outside of the corner of the intersection.
There's nothing wrong with half-lapping the mudsill, but the intent of the code is two bolts...One on each leg of a corner.
Old 09-05-2008, 03:00 PM   #3
I have gas!
Thanks, if that's the case, I'll skip the extra work of the half lap.
Old 09-05-2008, 03:07 PM   #4
Registered User
Termite's Avatar
I would. It just won't offer any benefit other than being nifty looking before you cover it up.
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 08:08 PM
Rotted sill plate replacement help handyd123 Building & Construction 2 08-25-2008 06:02 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Sill plate damage from water. Do I need to replace? twilightcall Building & Construction 4 06-05-2008 07:55 AM
Sill plate and pre-hung door sithappens Building & Construction 4 01-27-2008 06:18 AM
