Old 04-23-2009, 11:41 AM   #1
Gutter screens..best for pine needles?
So I’ve been working on the basement renovation and with that comes water control. I’ve taken care of the sore spots outside the house but still have one issue to address.
I have 2 large pine tree that extend over the house. The gist of my water issue is all the pine needles and cones that end up plugging the gutters and down spots. I do not have screens over the gutter and the last owned tried using a screen that was install in the down spout inside the gutter…well that gets plugged about every rainfall.
So I know I can pretty much use any screen to keep the pine cones out but how about the needles ? Will any old screen work or is one better than another? Any other suggestion welcomes. I could remove one tree but the other is on the neighbors property
Thanks!!
monsterbash is offline   Reply With Quote
Old 04-23-2009, 11:56 AM   #2
BIGRED
In your case I would recommend the 5" wide rolls of expanded gutter screens the entire length of your gutters. Then -and this will be a real pain, but it will keep the gutters and downspouts clear- figure out how many feet of gutter you are covering and cut enough 5" wide rolls of regular aluminum window screen out of a 3 foot wide roll of regular aluminum window screen and lay those strips on TOP of the gutter screens. A few needles may get caught, but knocking them off every 4-5 monthes is far better than cleaning plugged gutters every couple of monthes.
Grampa Bud is offline   Reply With Quote
Old 04-23-2009, 12:13 PM   #3
Actually that sounds like a great idea. I bought a 100' roll of screen to fix a couple screen doors the dog decide to go through and have a bunch left over.
Sounds like a nice little weekend project
Squirrels chewing the gutter guards... gshock Roofing 1 04-12-2009 01:47 PM
"Frozen" Gutter Leak cougar01 Roofing 19 02-10-2009 07:07 AM
How do you keep fir needles out of gutters? jimhorn1 Roofing 39 07-15-2008 12:01 AM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing 3 07-02-2008 03:10 AM
Proper way to install gutter flashing? Kasfidan Roofing 3 03-17-2008 01:57 AM
