Gutter Downspouts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-16-2008, 04:40 PM   #1
Rewards Points: 1,088
Gutter Downspouts
I see now that there are plastic gutter downspouts and fittings as options.
What's the benefit of plastic vs. aluminum besides not having to crimp? Do all joints need a seal and screws?
Also, is it not a big deal to mix and match?
handy man88 is offline   Reply With Quote
Old 09-16-2008, 08:27 PM   #2
The big benefit of plastic... does not dent like AL.
never did the mix and match thing
Big Bob is offline   Reply With Quote
Old 09-16-2008, 10:06 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Are you talking about Gutter systems as a whole, or just downspouts?
As far as plastic vs. aluminum: We have installed plastic gutter systems with plastic downspouts and had nothing but problems with them. Particularly at the seams. I would never, ever use them again, nor recommend them to anyone.
On the other hand, seamless aluminum gutters and aluminum downspouts have been completely problem free.
We use a gutter supply company. We contact them, and give them the address .....with the lengths and materials we want.
They come out to the property. Roll out our seamless gutter lengths. They leave the parts we need; anchors, downpsout sections, brackets, endcaps, elbows, sealant, etc.
We install the system = Can't get simpler than that.
- Build Well -
Old 09-16-2008, 10:39 PM   #4
I was mainly asking about the plastic gutter downspouts and elbows/fittings. They seem more available than aluminum elbows.
In fact, I wonder if an aluminum "double elbow" is available, or do two single elbows need to be joined.
How often do outside mitre seams need to be resealed? My house is 10 years old and it seems that the inside strip miter seams are dripping a bit of water during rains.
Also, is there a difference between gutter sealant (e.g. Henry) vs. a good waterproof caulk?
Old 09-17-2008, 08:23 AM   #5
Another question:
If you have corrugated piping connected to your downspouts and run underground, is it a good idea to put strainers on your downspout to prevent leaves from clogging your corrugated piping?
I've seen instances where strainers can get really clogged, with sludge or leaves, but it does prevent leaves/maple seeds from getting into the downspouts.
Old 09-17-2008, 08:55 AM   #6
the Musigician
DangerMouse's Avatar
i would certainly think so, as cleaning buried stuff could be a real pain in the...... how does everyone feel about the 'gutter helmet' type screens? i've seen lots of mixed reviews on them, but sure could use something like them when i do my new gutters. pros and cons guys?
DM
Gutter Heaters kennykenny Roofing/Siding 17 02-29-2012 03:43 PM
replacing gutter apron ponch37300 Roofing/Siding 5 07-31-2008 07:25 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 03:10 AM
Proper way to install gutter flashing? Kasfidan Roofing/Siding 3 03-17-2008 01:57 AM
facia repair and gutter boman47k Carpentry 2 09-11-2006 08:06 AM
