Grouting Fireplace Tile Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-28-2009, 02:28 PM   #1
Hello All,
Well, I've tiled my fireplace and hearth and will be doing the grout in a few days, but have a question.
The tiles are all set on diaganol. What will prevent the grout from 'sliding' downward to the firebox opening or outside legs? I realize the consistency of grout is to be like peanut butter and I've done grouting on floor tiles, but this is my first vertical and diaganol tiling project. I'm just wondering if the consistency of peanut butter will keep it where it's suppose to be and not do any sliding. The grout lines are 1/8-3/16". I have sanded grout.
Thanks for your help with this! Rox
roxksears is offline   Reply With Quote
Old 11-29-2009, 12:00 PM   #2
young diy bloke
its not that runny mate, its more like sorbet.
it shouldnt run, if ya worried try doin a small area and then see what happens,
peace
syborg
syborg is offline   Reply With Quote
Old 11-29-2009, 07:41 PM   #3
Syborg,
Thanks for the reply.
I realize the grout's consistency isn't runny, but didn't know about gravity's effect and having the 'grout channels' open with nothing for the grout to come up against.
You say do a small area and see what happens. So what would you suggest if it does happen? I like having another idea or solution in my arsenal before going at it. I've got time constraints that give me little time to dedicate to getting this grout job done.
Thank you!
Old 11-29-2009, 08:02 PM   #4
Concrete & Masonry
Rewards Points: 526
Originally Posted by roxksears View Post
Syborg,
Thank you!
Add more dry material to make it even stiffer.
jomama45 is online now   Reply With Quote
Old 11-29-2009, 08:21 PM   #5
Okay. Makes sense. Thanks
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 12:43 PM
Backerboard and Tile Project Question Livestrg05 Flooring 6 04-25-2009 08:35 AM
Replacing Fireplace Tile doldroyd Building & Construction 4 11-10-2008 04:04 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 01:08 PM
Marble Tile Question kidflash3002 Flooring 1 07-10-2008 07:49 PM
