#1 |
Location: Just moved to south Georgia, lived in Beijing China for the last three and half years.
Grout for a Shower floor
I have a couple of places on the shower floor where the grout is cracking and needs to be replaced. Just slong four tile actually. What grout is best for a shower floor? At the home supply store many types had not for shower use or for standing water or for temperatures above 100 degrees. It seems a shower floor would hit all of these exclusions at some point.
sanded? unsanded? I understand most premixed grouts become soft from the hot water making it impractical. Suggestions? |
#2 |
If the tiles are secured and the grout did not come out due to a bad substrate, you can use any good powdered grout. Hydromet, Latecrete or Custom are fine to use. The type of grout depends on the space between the tiles. Up to 1/8", you use unsanded. Above that, use sanded grout.
Check to see the tiles are not loose before you regrout. Ron |
| Display Modes | |
| Shower floor leaking...help! | slloyd | Plumbing | 5 | 06-13-2009 02:34 PM |
| Pre slope question on shower floor - did I do it wrong? | maestro300 | Flooring | 2 | 02-20-2009 03:44 AM |
| Shower floor confusion | heatherfeather | Remodeling | 17 | 06-25-2008 10:36 PM |
| Shower floor slope | Not Sure | Building & Construction | 11 | 06-10-2008 12:12 PM |
| Using concrete as grout for slate floor | sometimes handy | Flooring | 7 | 06-02-2008 11:28 PM |
