Old 10-17-2005, 05:59 PM   #1
grout problem
anyone ever use Mapei premixed grout/adhesive. I used it last year for a tiling job and it's starting to soften and fall out near the bottom of the shower. It was the first time i ever used the premixed. I'm gonna remove it and use unmixed grout. Just wondering if anybody might know anything about this.
farrington135 is offline   Reply With Quote
Old 10-17-2005, 06:01 PM   #2
rspainhower's Avatar
grout problem
Never use anything labeled pre-mixed in a shower/wet environment. It will always soften up no matter which brand.
rspainhower is offline   Reply With Quote
Old 10-17-2005, 06:09 PM   #3
grout problem
why is that?? I just want to know because I'm gonna call the tile guy that recommended it to me. I went against my better judgement when i bought it. thanks
Old 10-17-2005, 06:30 PM   #4
grout problem
The premixed stuff is not made with portland cement. It will loosen up and feel like toothpaste when it comes in contact with moisture. The proper product to use is thin-set and grout made with portland cement that is bought dry and mixed with water.
Help, glaze on my grout why??? theknuck Flooring 15 04-06-2012 08:51 PM
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 10:51 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 08:49 PM
Difficulty removing grout ????????? nsb318 Flooring 12 02-19-2007 11:47 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
